MAYBE ALIGNMENT?
Old Dec 13, 2007 | 11:28 AM
imsickofrice's Avatar
Default MAYBE ALIGNMENT?
ok ok first things first. I was drunk and came to a t section and i was speeding a little. swerved and luckily ran into a driveway for some parking lot. hit my right wheel pretty hard but yeah theres been a bounce on my front right wheel. im thinking it might be my ball joints but i may be wrong.
ever since that i dont drive when im drunk. and the after effects caused my alignment to drift to the right. and this morning i just noticed that my car drifts to the left now. what could the possibilities for this be and also what could cause the noise coming from my front passenger wheel?
Old Dec 13, 2007 | 11:31 AM
AWD Terror's Avatar
Default Re: MAYBE ALIGNMENT? (imsickofrice)
First....You should've hit a tree to learn your lesson.
You may have bent a rim, or any part of the suspesion for that matter. Get under the car and look. Then check the easy things: wheel bearing, tie rods, and ball joint
Old Dec 13, 2007 | 11:40 AM
Default Re: MAYBE ALIGNMENT? (AWD Terror)
but as far as my alignment, what could cause sudden change in direction? from right to left?
Old Dec 13, 2007 | 11:41 AM
AWD Terror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imsickofrice &raquo;</TD></TR><TR><TD CLASS="quote">but as far as my alignment, what could cause sudden change in direction? from right to left?</TD></TR></TABLE>
If something's loose, it will change from day to day. Hit a bump hard enough, and then it will pull the other way
Old Dec 13, 2007 | 11:58 AM
hmmm thanks
ke98248
Oct 23, 2007 12:10 PM
DAP97SI
12
Jun 4, 2007 01:51 PM
90efSI
12
Mar 11, 2007 08:53 PM
94eh2
Feb 15, 2007 02:05 PM
Rpc07
Dec 6, 2004 03:59 PM
