Polishing Manifold/Ic pipes HELP
My questions never get answered in the cosmetic forum so I'm gonna try here. My greddy manifold/ic pipes look like *** and I need to make them look better. How would I go about polishing them. Use polish and rub on or use sand papper and what grit. Help thxs
Re: Polishing Manifold/Ic pipes HELP (TurboSohc)
dremel + polishing compound for i/c pipes
as for your manifolds, all cast iron manifolds end up looking crappy. you can sand blast it if you want, that might help.
They're all steel so there's nothing you can do with them except powder coat or chrome them. The manifold you can have jet-hot coated or something similar.
Location: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
I'm goign to just wing it and see what happens, .. .er.... hope I don't do something bad!
I'm just going to start with some ULTRA FINE sand paper. Say like... 4000 grit and stuff. Then smoot it out, wash it up, and then use some stainless steel polish since my turbo manifold is stainless. (thanks maxrev!)
Re: Polishing Manifold/Ic pipes HELP (Snafu-Si)
but don't forget to SPRAY it w/ a clear coat.....otherwise it'll just start to rust...i'm in that boat!, doing the work all over again because i forgot to buy clear coat....
Re: Polishing Manifold/Ic pipes HELP (98civicEX)
Stainless Steel has a clear coat? Thanks for the headups.
you shouldnt polish those pieces, maybe the piping but not the manifold. i took my manifold and turbine section and had it ceramic coated and it looks sweet. you should either powder coat them or spay them with a high temperature paint
Re: Polishing Manifold/Ic pipes HELP (d16twannabe)
Thanks, I'll think about that.
Say.. how much does it cost to ceramic coat it?
And what are teh benifits of doing so anyway?
[Modified by Snafu-Si, 2:50 AM 4/27/2002]
Well Im gonna attempt to polish the ic pipes and fmic but for the manifold since its iron im gonna just spray it with a high temp paint. THXS
994TurboCoupe
Welding / Fabrication
01-17-2006 08:10 AM
