can someone post a pic of the flange of the max rev manifold or.....
can someone post a pic of the flange of the max rev manifold where it would meet the turbo. or post pix of other manifolds. i have a rev hard cast manifold and i cant not seem to keep my bolts from falling out. they lasted 6 hours before they fell off. i used red loctite and locwashers. i was thinkin about welding them but im not really sure. anyhelp?
Re: can someone post a pic of the flange of the max rev manifold or..... (PROFILEGSR)
don't weld your bolts on or you will have a hell of a time trying to fit a grinder in weird positions to get them off later. maybe your car is just vibrating too much? do you have a flexpipe? or poly motor mounts? try to control the vibration & torque shifting of your motor & maybe you'll have better luck.
Re: can someone post a pic of the flange of the max rev manifold or..... (qwkteg125)
i have a flex pipe.....i know that you have to watch those bolts alot but i mean i cant drive it longer than a day before they fall out
throw some lock-tite one there and let them sit together for a while, get some lock washers, or i dont know if this will work but try a double nut system if your bolts are long enough.
Re: can someone post a pic of the flange of the max rev manifold or..... (JoshM)
i know i know ive done this done that.......am i the only one who has had a hard time with these bolts?
sublimital message................SHOW PIX OF MAX REV (the other manifold not the brand new one........the one that dustin has, what did all the posts on that manifold dissapear? there was liek a 45 page article on the board about it)
I dont know if this will help, but heres pics of mine. There isnt any angles of the flange from the bottom side though.
http://mywebpages.comcast.net/turbocivx/MaxRev/
Location: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Re: can someone post a pic of the flange of the max rev manifold or..... (93LSivic)
How the hell did you polish that thingy so damn shiny? I have the same kit and parts, and it came just as dirty as yours did out of the box. What did you use?
Re: can someone post a pic of the flange of the max rev manifold or..... (Snafu-Si)
Look at my reply here
https://honda-tech.com/zerothread?id=173683
Hey profile, I think I have figured why your bolts are coming loose. Do you have a flexpipe on your downpipe?
Im me when you get a chance.
EVIL
EVIL
unforunetly i was able to see plenty of with those pix....it doesnt look liek i would be able to keep my current downpipe setup.....oh EVIL i have a flex pipe...
is there a manifold that will fit in place that is made identical to the rev hard but with out teh same bolt setup?
YOu have too much time for yourself. Get a job SLACKER! J/K.
That's really nice work. Think I'll try it out. have pics of those U Bends?
