CRVTEC turbo?
Old Apr 27, 2002 | 10:04 PM
turbopanda's Avatar
Default CRVTEC turbo?
I'm still waiting on a B18C engine.. but the guy who's doing my car said that he can drop in a CRVTEC right now if I wanted it. Problem is, I don't have enough money now for pistons/rods, so I was just curious as to how much boost could be handled by a stock b20b block with b16a head..
Old Apr 27, 2002 | 10:15 PM
rainforest's Avatar
Default Re: CRVTEC turbo? (nathan's boosted civic)
ok, first off the wastegate on the ls kits ive seen are 8 p.s.i so listen to the companys sellin the kits. get more fuel and shot pein the rods and then you should be fine to you build the block.
Old Apr 27, 2002 | 11:00 PM
turbopanda's Avatar
Default Re: CRVTEC turbo? (rainforest)
dude, i'm not playing with any "drag" turbokit. its all custom. I have everything I need already. Even have a standalone ECU. I just want to know, without doing ANYTHING to the internals (apart from lowering compression with a new headgasket and installing a blockguard) how much BOOST it can take. Can anyone else here be of more help?
Old Apr 28, 2002 | 12:54 AM
paulzy's Avatar
will the valve clearance be ok with stock b20 pistons and vtec valves? I thought it was different than the LS/VTEC where you can still use stock pistons
Old Apr 28, 2002 | 06:24 AM
SpeedMonkeyRacing's Avatar
Default Re: CRVTEC turbo? (Slow_ass_4dr)
you can still use oem parts. it's a trade secret in asia
Jeff-
Old Apr 28, 2002 | 06:55 AM
Tomakit's Avatar
Default Re: CRVTEC turbo? (Corporal-Jeff)
Should be fine at 8. 10 would be pushing it, imho.
Tom
Old Apr 28, 2002 | 08:43 AM
turbopanda's Avatar
Default Re: CRVTEC turbo? (Tomakit)
Anyone have any opinions on that 8-10psi? I have ordered some 550cc RC injectors already, and am using an IHI RHF5 ballbearing turbo.. a link to my turbo maps can be found here http://ihi-turbo.com/turbo_RHE-RHF.htm Much help would be appreciated
Old Apr 28, 2002 | 08:44 AM
b18bturbo's Avatar
8-10 psi should be fine but you really cant rev it like a gsr. I wouldnt take it past 8000rpm.
I also would check the piston to valve clearance as well to make sure you are in spec incase your GSR head was milled etc.
Old Apr 28, 2002 | 08:56 AM
quikB18B's Avatar
Default Re: CRVTEC turbo? (b18bturbo)
I have a stock bottom end and i'm playing it on the safeside for now. 6.5 psi
Old Apr 28, 2002 | 09:04 AM
Mr. Vapor's Avatar
Default Re: CRVTEC turbo? (quikb20)
the b20 bottom has a different cylinder walls then the b16 and b18, its composed of different materials. its slightly stronger and if i remember correclty slightly thicker. so it should by theory in its stock form be able to handle a few more PSI then its smaller counterparts.
Old Apr 28, 2002 | 09:30 AM
turbopanda's Avatar
Default Re: CRVTEC turbo? (NYb16)
i actually heard quite the opposite of that. I heard that B20 rods are as thin as toothpics, and the pistons aren't all that strong.. also that the cylinder walls are thinner than that of B18/B16 engines due to the increased size of the pistons..
[Modified by nathan's boosted civic, 1:48 AM 4/29/2002]
Old Apr 28, 2002 | 05:07 PM
Ri5e's Avatar
Actually, the cylinder walls are THICKER then the B18B engine. I had my LS block next to the CRV block, and the difference is pretty big. The walls are thicker, but the water jacket is a lot smaller.
Old May 11, 2002 | 12:46 AM
Tuan's Avatar
Default Re: CRVTEC turbo? (BG Boost)
Can anybody verify this? This is very interesting! You would think since your increasing .2 liter, I wonder what they did to sacrifice the block./
Old May 11, 2002 | 06:17 AM
rioninja's Avatar
Yeah, the CRV block definatly has thicker/stronger sleeves. Its not just a bored LS. The rods are pretty much identical to LS rods, which people seem to be able to push a lot of boost on.
If you have a standalone and are not worried about detonation, then i would not hesitate to push 10psi. But, thats just me
Old May 11, 2002 | 10:19 AM
Tuan's Avatar
Default Re: CRVTEC turbo? (RioNinja)
I'm a newbie, what is a standalone?
Old May 11, 2002 | 02:39 PM
intekragsr's Avatar
Default Re: CRVTEC turbo? (roku21)
http://www.hondata.com <---most popular one around this board
Old May 11, 2002 | 06:00 PM
TheSwift1's Avatar
http://www.crvtec.com
the B20 block has super thick *** sleeves compared to other Bseries engines...
B16afmaxt
Nov 11, 2009 04:27 PM
chb93
Mar 25, 2009 03:45 PM
mcgee*
Jan 24, 2007 04:16 AM
b16ahybrid
May 8, 2005 01:31 PM
JICsube
Jan 18, 2003 11:42 AM
