not the fmu it's a problem with the inline pump?(please read)
Old Apr 26, 2002 | 01:44 PM
uneekcrx's Avatar
Default not the fmu it's a problem with the inline pump?(please read)
ok it might not be the fmu....here's what i have i took the fmu apart and cleaned the disc...and put it back together correctly....but the fuel pressure is still around 80psi and bogging the car at idle...but when i turn off the inline pump..everything runs pefectly idling at 40psi of fuel pressure and not bogging....but when i turn the inline pump back onit jumps the fuel pressure back up to 80psi and the car practically dies...i don't understand....could my problem be the inline pump???? someone please help me out here before i break something
-thanx
Old Apr 26, 2002 | 01:55 PM
SUMORex's Avatar
Default Re: not the fmu it's a problem with the inline pump?(please read) (uneekcrx)
Do you have a AEM FPR?
If so, i can promise you its that. The diaphram inside it always breaks after a certain amount of time.
If you dont have a AEM FPR then yes it possibly may be your Fuel pump./
Old Apr 26, 2002 | 02:43 PM
uneekcrx's Avatar
Default Re: not the fmu it's a problem with the inline pump?(please read) (SUMORex)
i have a b&m feulpress. reg.
Old Apr 26, 2002 | 02:58 PM
supergreenNA1's Avatar
New User
are you talking about the aem fpr that replaces the stock fpr?? if so, this concers me.. because i have one. did that happen to you?
Old Apr 26, 2002 | 03:02 PM
chri5's Avatar
Well, that does sound like it may be the pump...
Old Apr 26, 2002 | 04:08 PM
uneekcrx's Avatar
Default Re: not the fmu it's a problem with the inline pump?(please read) (Strng1dah)
what could cause an inline pump to malfunction like that?....grounding out somewhere?
maybe?
Old Apr 26, 2002 | 06:46 PM
uneekcrx's Avatar
could it be a malfunctioning injector...being stuck open?? is this possible... i checked my plugs the other day and i think injector #4 is going out...
-anyone???
Old Apr 26, 2002 | 07:52 PM
turbosol's Avatar
Did you try to lower you fuel pressure with the b&m?
importimage
Jul 11, 2003 03:45 PM
Endless
Aug 11, 2002 03:51 PM
TURBOED-TEG
May 3, 2002 05:08 AM
97GSRT
Mar 28, 2002 04:21 AM
Dravis
Oct 9, 2001 02:32 PM
