Tial wastegate install q?
I ordered a Tial wastegate from VSracing, yesterday. I am hoping to see it soon. i noticed that the tial has 2 fittings on it. I was wondering which fitting do I use to hook up my electronic boost controller? Also, what do I do with the other fitting because my deltagate has only one?
Re: Tial wastegate install q? (CRXRageD)
Re: Tial wastegate install q? (Slow_ass_4dr)
well the current setup is with my deltagate. it has no top fitting. the side fitting is hooked up to the ebc. the other fitting to the ebc is coming off the compressor housing of the turbo. I am clear on the top fitting, now what do I do with the side fitting?
[Modified by CRXRageD, 4:37 PM 4/27/2002]
What kind of EBC do you have? If your Deltagate has its side fitting hooked up to the output side of your EBC, then I suppose you would hook your EBC up to the side fitting of the TiAL, but I've never seen an electronic boost controller that hooked up to the side(boost) fitting of a wastegate. Generally, the side fitting gets hooked up to a boost signal as usual, and the EBC solenoid is fed by another boost signal, with its output side going to the top(vacuum) side of the w/g. The boost signal from the EBC pushes against the w/g on the top(against the boost signal from the side fitting) to keep it closed.
Re: Tial wastegate install q? (inspyral)
I have a greddy profec b on the car right now. I am going to replace that with a blitz sbc id. the greddy is hooked up to the side fitting of the deltagate. the other fitting is hooked up to the compressor housing to the greddy solenoid.
I see. Well, if the GReddy unit is hooked up to the boost side of the Deltagate, then you'll want to hook it up to the boost side of the TiAL as well. If you're going to an SBC-iD, I'm guessing it's plumbed similarly to my SSBC, which is boost signal to the boost side of the the w/g, and SBC signal to the vac side of the w/g
I'll buy your profec B for 175 bucks...
That's weird. My AVC-R runs one port (COM) to the top part of the w/g (Tial). One port sees atmosphere (NC), and the third port (NO) runs to a "T" between my compressor housing and the side port on the wastegate. Hard to describe but it seems to work ok... EV.
Re: Tial wastegate install q? (ElectronVTEC)
well everyone, I have to say thanks for the information. I won't know til I recieve it and hook it up. As soon as the UPS or postal guy delivers it. It's goin in unless it's raining. I'll try every seutp till it works.
