drag slicks
Old Apr 25, 2002 | 06:22 PM
98civicEX's Avatar
Default drag slicks
i'm looking to buy some drag slicks, i've been looking around and can't find anyone who has a size that will fit my 15 inch steels for my 98 civic with a 2 1/4 drop....any help would be appreciated...what particular size? place to get the from? general pricing?
Old Apr 25, 2002 | 08:12 PM
PrecisionH23a's Avatar
Default Re: drag slicks (98civicEX)
Micky Thompson's are my slicks of choice. They run about 140-150$ a piece. 22-8.5-15 is a good size to run. I am not really sure who to order them from online, a local performance shop should be able to order these for you.
Old Apr 25, 2002 | 08:14 PM
paulzy's Avatar
Default Re: drag slicks (GudeH23a)
yeah, the mickey thompson 22x8x15 should fit and be good for your setup
Old Apr 25, 2002 | 09:32 PM
ExospeedAMcrx's Avatar
dont run 15" slicks. go for the 13" fatties and push those.
Wil
Old Apr 25, 2002 | 09:33 PM
BoostinDC2's Avatar
Default Re: drag slicks (exospeedAMcrx)
you dont need 15 inch slicks unless you are planning on running a 26 inch slick or bigger other than that just stick with the 13 inch
Old Apr 25, 2002 | 10:25 PM
93LSivic's Avatar
Sorta off your topic---sorry, but looks like you got your answer here.
I have a question.
I have 14" black steelies in the garage. Should i spend the money on new slicks for them, or should i spend the money and get 13's and slicks? I decided to stay with the 9.x" front brakes just cause i knew i was gonna run 13's some day.
Would there be a huge benefit to run the 13's over the 14's with only about 250 hp?
Old Apr 25, 2002 | 11:25 PM
DLB1994's Avatar
Default Re: drag slicks (93LSivic)
i got 15-8-22 M/T
Old Apr 25, 2002 | 11:32 PM
sparkz's Avatar
15" slicks will be fine if you already have a set of lightweight 15" wheels laying around. in my case, i have some mt 22x8x15 mounted on ssr type x's. if you dont already have rims and/or slicks, then i suggest some 13's like the lenso vpd's or some bogarts with 22x8.5x13 slicks
Old Apr 26, 2002 | 10:02 PM
rocket_R's Avatar
Default Re: drag slicks (sparkz)
what psi are you guys setting it on your m/t slicks for the 22x8x15?
Old Apr 27, 2002 | 12:08 PM
sparkz's Avatar
Default Re: drag slicks (rocket_R)
about 10psi
Old Apr 27, 2002 | 12:13 PM
jinxproof99's Avatar
New User
I have a question.
probably wouldn't be a huge benefit but i'd get the 13's anyway. then, the more power you come up with, the better off you'll be with the 13's.
SlowEG16
Apr 23, 2013 04:48 PM
kidkutz
May 14, 2002 01:49 PM
ExospeedAMcrx
May 10, 2002 03:02 PM
Black R
Feb 2, 2002 12:29 PM
