Greddy oil temp & press gauge? help!
I have 52mm electrical gauges for oil temp and oil pressure. Should I buy me this CREX adapter which gets between the oil filter flanch and oilfilter for an easy sensor hook up? Can I use stock ITR oil filters or do I have to switch to another brand?
Or tell me an other way how and where to install these 2 sensors. Thanks!
Re: Greddy oil temp & press gauge? help! (austrian type-R)
I recomend you the block adapter or the filter relocator (I use the filter relocator and I'm very happy)... this is the cleaner way. If you buy the Greddy block adapter or filter relocator you need Toyota Corolla GTS (85-87) Oil filter (K&N: HP-1003 / Fram: PH2951 / Mobil: M1-103)
Re: Greddy oil temp & press gauge? help! (dariusz)
Yea, the adaptor and oil cooler kit both have a couple bungs built in so you can put a pressure sending unit and a feed line if you youl ike.
Re: Greddy oil temp & press gauge? help! (Boosted Ego)
Are those Toyota oilfilters good for the Integra?
[Modified by austrian type-R, 6:07 PM 4/27/2002]
