Can I just us an ls block instead of a GSR block?
I'm having a hard time finding a spare GSR block for a decent price but I acutally found an LS block for $100 within driving distance. Would it be much better/worse to just have GE re-sleeve the LS block and have it put in my GSR when it come back, then I could just sell my GSR block and make out decently well with $$?
Re: Can I just us an ls block instead of a GSR block? (jamal-188)
no..just wait for the downtime. gsr sleeved block is much better than ls sleeved block...i mean unless you wanna get rid of vtec or else you have to do mods to the ls block to make it compatible w/ vtec head
Jeff-
Jeff-
Re: Can I just us an ls block instead of a GSR block? (On Point EK)
So Vtec won't work w/ a LS block? I dont' know too much about block work and stuff? I can't live w/ the down time cause this is my only car!! By the time I tear the block down send it in for the groupbuy then he sends it to GE etc... I won't hav ea car for 6-8 weeks.
Banned
vte will work, u are gonna have to do whatthey call Ls/Vtec, u will need a oil line and 2 holes nlarged and 2 holes filled, a machine shop could do that for u
Umm, why not just send out the LS block and then make a sick *** LS/VTEC turbo monster?
You could always sell the GSR block--they are hard to find right now since its race season and all.
Just my .02
Just my .02
Re: Can I just us an ls block instead of a GSR block? (93LSivic)
Yeah, I think I'd need one of those Z10 Block Gridle(spelling) to support higher revs right? Do you guys think this would be okay or should i just try to find a GSR block? I mean this is a 01 GSR so I dont' really want to be downgrading!
1 Post
you wont be downgrading. The LS vtec setup is great for turbos.
If you build up the LS block, then you'll have a GSR block as a spare later on. http://www.exospeed.com/ls.htm
Wil
Wil
Sorry, had to give some **** back to you for the downgrading comment
So what is the actual difference between the LS and GSR block?
The LS block has like 93cc more displacement than the GSR block, this would yeild more overall torque. The LS block does have a 1.54 rod stroke ratio, as opposed to the GSRs 1.58 (that should be right) which is why you either would want to use the Z10 girdle or a modded GSR girdle. (I don't have one ) Also, LS's don't have a factory knock sensor, but do have a slightly ligher flywheel (so I've been told). You can either use the lower compression LS pistons or higher GSR pistons in the block, but I would assume you are going to buy some forged components.
The LSVT conversion is a bit more involved than what was said in my and previous posts. It requires a bit of research and someone who knows what they are doing to build it. Plus it's not that cheap, you will need to swap some parts to make sure it's reliable. To keep costs down and reduce labor requirements, I would stay with the GSR block... try to find one.
main differences in the block lie in the R/S ratio, oil jets(squirters), block girdle
LS = 1.54:1 R/S ratio \____ **** the R/S ratio it's not THAT important
GS-R = 1.58:1 R/S ratio /
Granted the GS-R R/S is a bit more favorable to higher RPMs than the LS but not that much. What 2%, thats not enough to justify a 1000 RPM higher rev limit. Niether one is any where near the rev happy 1.74 R/S of the B16.
GS-R's have oil jets(squirters) and LS engines don't. The main effect of these is to spary the undersides of the pistons and the wrist pins. This helps with lubrication, and jeeping the stock cast pistons cool. With a good set of forged piston(JE/SRP/Wiseco/etc) you don't really need the oil jets. Forged pistons have a lot better cooling properties than the stock honda cast pistons.
The GS-R have a 3 main cap block girdle that helps to keep the bottom end rigid when you're revving the **** out of it. The GS-R girdle can be adapted to the LS bottom-end with relative ease. I've done it. I consider this part one of the keys to the GS-R's higher revving potential.
One a side note, a minor difference in the bottom-end is that the GS-Rs have 1mm longer rod bolts. These are most likely a bit stronger than the LS components. Just for reference the LS uses and 8mm bolt(same as the D-seies) the GS-R uses a 9mm
Re: Can I just us an ls block instead of a GSR block? (Speed PHreak)
Re: Can I just us an ls block instead of a GSR block? (X2BOARD)
As I understand it, the differences between the two blocks lie in that the GSR block has the oil squirters, the block girdle and the correct oil passages to work with a VTEC head. The oil squirters aren't a big deal, but the other two things are and a block girdle from Z10 is going to cost 200+ plus you are going to need take it to a machine shop to have it properly installed. The LS block is also going to need to be modified to accomodate the VTEC head so that will cost extra too.
So it's not going to be just 100 dollars for the block. Add in the other stuff that you'll need to get it to work to find out the true cost. That'll give you a better idea of the cost difference between a LS block and GSR block.
Re: Can I just us an ls block instead of a GSR block? (DarksideDC4)
Whoa, whoa, I'm gonna have to go out on a limb here and disagree, since he's getting just the block right? I'm pretty sure the differences in displacement and rod and stroke between the LS and GSR engine are NOT due to the block but due to the different crank and rod lengths. Since you are keeping all the other parts from your GSR then you will not be getting the extra displacement or poorer rod to stroke ratio.
No one has actually answered the question tho... can one use an LS black if they are swapping over the GSR internals ? Basically an LSVT setup would have to be done to get the oil passages I assume, but would it be OK and can the GSR oil squirters be transplanted ?
Does any modification have to be performed to the LS block to do this ?
NICOSLOW
12-23-2009 05:04 AM
