problems w/ nitrous kit... help! please
Old Apr 25, 2002 | 03:52 PM
allshownogo7's Avatar
Default problems w/ nitrous kit... help! please
when i open the bottle valve to release the nitrous i hear a hissing noise commin out of my nitrous nozzle. i have a ZEX kit by the way. there is air leaking ONLY through the nozzle. what's wrong? how can i fix it, if possible? thanx!
Old Apr 25, 2002 | 05:55 PM
Default Re: problems w/ nitrous kit... help! please (allshownogo7)
anybody...? please i appreciate it.
Old Apr 25, 2002 | 06:09 PM
b18bturbo's Avatar
it shouldnt leak if all your an fittings are tight you should hear anyhting leak out. verify your fitting and make sure you line doesnt leak as well. Some times they come damaged.
Old Apr 25, 2002 | 06:15 PM
Default Re: problems w/ nitrous kit... help! please (b18bturbo)
i checked all my lines & none of them leak. everything is as tight as can be. no visable signs either. the only place i hear nitrous leaking from is the nozzle going to the intake. could it be i have a jacked up solenoid? i don't arm the system but it's still leaking outta there.
Old May 2, 2002 | 01:09 PM
EVOCELICA's Avatar
New User
you have a clogged solenoid that is stuck partially open.
civicx98
Honda Civic (2006 - 2015)
Jun 30, 2007 07:44 PM
JWHATCH23
Oct 4, 2006 12:23 AM
DarkDragon
Jul 26, 2005 07:38 PM
allshownogo7
Feb 21, 2002 09:30 PM
