Polishing ic pipes..... WHAT A PAIN IN THE ASS....
Polishing ic pipes..... WHAT A PAIN IN THE ***....
Jesus well I started this project from hell around 1pm today after I made a quick stop at kmart . I picked up some simple green to clean the engine some chrome/polish finish by turtle wax and some assorted sand papper (60,120,150,220 grit) Took all my ic pipes off. Then cleaned one U pipe with some simple green then started with the 60 grit papper. In total it took me 4 hours to sand/polish 2 pipes. Actually thinking about it. It looks like a brushed aluminium finish. I like the results for far. Much better then the moron who spray painted them silver . Tommorow I hope to finish up.
Re: Polishing ic pipes..... WHAT A PAIN IN THE ***.... (project dc2)
what grit is requried for a mirror finish? so, this could all be done by hand?
Re: Polishing ic pipes..... WHAT A PAIN IN THE ***.... (boostedeg6)
Someone here polished their turbo housing they started with like 60 and worked their way to 1000.
Re: Polishing ic pipes..... WHAT A PAIN IN THE ***.... (turbocoupe)
Get buffing compound and use a buffing wheel. Either a hand held wheel with the pipe gently clamped in a padded vice or a buffing wheel on a bench grinder. Use lots of buffing compound and then use polishing compound. To keep it that way, maybe clear coat it??? The other stuff works great! You can get a pretty good mirror going with just no. 7 buffing compound very fast, and if your **** retentive then use the polishing compound. You could probably do a 2ft section of 2.5" pipe in 30 min.
-Dustin
-Dustin
Re: Polishing ic pipes..... WHAT A PAIN IN THE ***.... (Autocratic_1st_Gen)
Yeah since the pipes are steel if you do not clear coat it will rust...might rust anyway. The clearcoat may also turn yellow from the heat...powdercoating is probably the best option. (without trying to polish)
[Modified by mplex2000, 7:58 AM 4/28/2002]
Re: Polishing ic pipes..... WHAT A PAIN IN THE ***.... (TurboSohc)
I polished my turbo manifold starting with 240, then 350, 400, 1000, and finished with 1500. Then I polished using a buffing wheel with the white rouge.
Unless you have aluminum piping, it will probably look good for the first 2 weeks. After that you will probably just want to paint them.
Location: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Re: Polishing ic pipes..... WHAT A PAIN IN THE ***.... (93LSivic)
How much does powdercoating, ceramic coating, or just painting them usually cost? Under... say.. 10$??
Yeah yeah, I know, probably not that cheap.. let me know.
Re: Polishing ic pipes..... WHAT A PAIN IN THE ***.... (Snafu-Si)
Hmm, I used the hybrid forum favorite--good ol' flat black for all but one piece of my charge piping. So far its working great. Oh yeah, lets see maybe a total of about $4.50 for one can of paint?
What is the advantage of painting or powerdercoating or ceramic coating youru turbo manifold anyway? IS there a good reason?
New User
Re: Polishing ic pipes..... WHAT A PAIN IN THE ***.... (uneekcrx)
My piping is black powdercoated.. and my valve cover is too....
[Modified by SiR Kid, 2:18 PM 4/28/2002]
Re: Polishing ic pipes..... WHAT A PAIN IN THE ***.... (dustin)
Hmmm.. I'll look into it, but not just yet, maybe as something to do next year when the time comes that I actually ahve some money to spend.
Thanks for the info, I really appreciate it.
Will you make something up for me please?
Hey Dustin...I thought you had a GSR. Looks like your manifold, but not your motor. Hehe.
