Internal / External wastegate Apexi turbo
New User
Does the Apexi turbo for the Civics come with an internal or external wastegate?
Also if you have an interal wastegate, but you have a boost controller can you run a greater amount of boost, higher than the stock boost of say... 7psi.
If so, what do you think max boost will be?
Re: Internal / External wastegate Apexi turbo (OPTIMUS)
Don't know if is internal or external wg, but even if it is internal wg, yes you can run higher boost with a boost controller.
New User
Dumb question ? Or Maybe?
Can you change the interal wastegate to an external wastegate?
It's an internal wg and yes you can change it. You will need to have a wg flange welded on your manifold and depending on how the dp is setup you need to usually just put a pipe from the internal wg location back into the dp.
ladysman
07-17-2003 09:13 AM
Broken Gearbox
06-08-2003 02:12 PM
OPTIMUS
04-24-2002 11:11 AM
