FI guys what kind of spark plug wires are you using?
i should replace my wires cause there mighty old, but i'm not sure what brand to buy. ( i did a search didnt find anything...). Anyone using good aftermarket and do you see a difference? i'm running a rev hard kit at 8 psi.
Re: FI guys what kind of spark plug wires are you using? (stealthteg)
either you started a relly long thread or everyone wil ignore, I run MSD, there are alot of good wires out there, even more bad ones, stay away from any gimmicky good looking wires, oh yeah and NGKs suck *****. stockers almost better than any toucan int'l crap or anything that advetises capacitor ground wires sounds like they are full of JDM poo.
Re: FI guys what kind of spark plug wires are you using? (rtype11)
stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock stock
get the point ?
get the point ?
NGK Wires=
On a related note, I remember buying pepboys 'el-cheapo wires for my gf's jetta, man did they arc and cause all kinds of problems....
Re: FI guys what kind of spark plug wires are you using? (DRAGLS)
bad experience with the blue NGKs, my they kept coming off the plugs or cap, one time I was at a red light and said to my copilot that the car was on three cyl's so I popped the hood and he went to check it out, #3 was right off and arking to my intake pipe, he grabbed it wothout thinking and replaced to #3 cyl, he got a very bad shock compliments of a MSD 7Al and HVC coil, he said he couldnt jerk off for a week it was so numb. I even use wire looms to help support the wires, theyare just crap.
I've first been through Magnecors, they sure do suck ****. The boots would often fall off and the snug fit on the spark plugs would loosen over time. I'm quite happy with my MSDs, they're more snug and tighter than I thought.
New User
I've used magnecor, ngk, neuspeed, and a host of others.
The conclusion? Stock works the best, fits the best, lasts the longest, and none of them made a measurable difference over stock on the dyno.
Rado uses stock spark plug wires What more do YOU need?
New User
Re: FI guys what kind of spark plug wires are you using? (VTC_CiViC)
i like my VITEK wires. had two sets for both my cars.. never had a problem. sent my old set in because the boot came off the wire.. and they replaced it with a brand new set. they have excellent customer service.
i thought magnecores and ngks were good?
MSD is known for good quality wires as well. stock is good as well.. but i think its mainly made for "stock" power.
Re: FI guys what kind of spark plug wires are you using? (dlplayboy)
I run MSDs just to keep it in the ignition family... But haven't noticed much anything over stock. MSDs= $60
Re: FI guys what kind of spark plug wires are you using? (LEON)
stocks are great, i just took mine out though becuase i upgraded everything igniton wise , and went all msd.
Re: FI guys what kind of spark plug wires are you using? (itr206)
accel wires, MSD 6T, soft rev control, blaster 2 coil
on my stock set up i could not boost over 9psi or i will get miss fire
Re: FI guys what kind of spark plug wires are you using? (97CivicFerio)
Yeah, my NGK are fine. Higher resistance than some. MSD are the best though. Or you could waste your mone on those Nology wires. Do they even make those anymore. I would not say stock are the best, that's rediculous, but they are probably better than Ractive or whatever.
Oh yeah, and if you check out the Magnecor you will see they are some of the worst performing wires available. But at least they cost more than most others!
[Modified by mplex2000, 9:39 PM 4/24/2002]
Re: FI guys what kind of spark plug wires are you using? (jinxproof99)
yea man , i know alot of guys stillusung stock wires. . .
chris rado still uses stock wires in his integra. believe it or not . he does.
i had a set a while back.msd..man did that **** fall off all the time!@!!!!!!!!!!!
the number 3 cylinder one would not stay on...even after i made the little connector tighter to fit better.it always fell off under spirited driving. so.i sold them to some guy .i actually asked him a how they were. he said fine! guess he drives slow or somethign(or i drive to crazy) im back to stock and will leave it that way!
