Only getting boost for a second during shift.....then 0psi????
Old Apr 24, 2002 | 09:21 AM
shamoo's Avatar
Will you make something up for me please?
Default Only getting boost for a second during shift.....then 0psi????
My friend is having a prototype turbo system put on a 2001 Celica GT automatic. It's basically done, however it boosts to about 7psi during a shift, and only during a shift, then it goes back to 0psi.
The fuel system is fine, it's reading pretty much rich all the way through. He has a Tial wastegate, a Garret T3/T04E, 270 injectors (will upgrade to 310's), S-AFC, and that's about all the important stuff.
No hoses popped off or anything either. What could it be?
Thanks guys.
Old Apr 24, 2002 | 09:29 AM
rtype11's Avatar
Default Re: Only getting boost for a second during shift.....then 0psi???? (shamoo)
there should be no real loss of boost during a shift in a slushbox, maybe his tqconverter has some really bad shifts programmed. must be the the computer taking out all the fuel in a shift ???
Old Apr 24, 2002 | 09:33 AM
shamoo's Avatar
Default Re: Only getting boost for a second during shift.....then 0psi???? (rtype11)
It's actually the opposite kinda. It only boosts when it's shifting. No boost when he's driving in gear. He also said the A/F gauge shows rich everywhere.
Old Apr 24, 2002 | 08:40 PM
shamoo's Avatar
Old Apr 24, 2002 | 09:32 PM
rioninja's Avatar
possible that the gasket is blown out between the turbo and manifold, or its wastegate related.
Old Apr 24, 2002 | 09:39 PM
falcongsr's Avatar
What is this crap?
Default Re: Only getting boost for a second during shift.....then 0psi???? (RioNinja)
sounds like oversized turbo. when it gets to upper rpm, it spools, then when u enter the next gear, not enough exhaust backpressure and it falls flat. oversized turbine wheel i should say...
just a guess.
Old Apr 25, 2002 | 12:08 AM
DLB1994's Avatar
Default Re: Only getting boost for a second during shift.....then 0psi???? (falconGSR)
yeh with a auto u need a small turbine housing
Old Apr 25, 2002 | 04:09 AM
RGAZ's Avatar
New User
Are you hearing a BOV? Are you sure you have the wastegate hooked up right? It sounds like the wastegate opens under 0psi and closes under vacuum. Recheck your wastegate and BOV connections.
Randy
Old Apr 25, 2002 | 10:41 AM
93LSivic's Avatar
just a guess.
I agree. Did anyone bother reading compressor maps and actually matching a turbo for that motor?
Also what size on the turbine is he using? Sounds too big to me....oh yeah and auto turbo cars need smaller turbos too.
Old Apr 25, 2002 | 04:37 PM
zojirushi's Avatar
Default Re: Only getting boost for a second during shift.....then 0psi???? (93LSivic)
problem solved... i talked to the kid, and the problem dealt with a faulty vacume hose.
draggbody
May 26, 2012 02:46 AM
blkeg2
Aug 19, 2004 02:52 PM
ineedhelp
Feb 2, 2003 08:41 PM
93LSivic
Apr 29, 2002 03:35 AM
FIxALPHA
Sep 23, 2001 05:27 PM
