turbo oil line fitting?
I've seen a bunch of pics where people have a fitting threaded right into the turbo center section with no flange. what are the threads for that fitting? getting ready to order
Re: turbo oil line fitting? (racerxadam)
Adam, I used Earls pn# 982244. 90 degree -4 to 1/4 NPT adapter. That should do you....This is for the feed obviously.
The return flange can be found at rre.com or most any other turbo retailer.
Re: turbo oil line fitting? (93LSivic)
I just replaced the feed hose on my Drag kit and the line was a -3AN and went right into the fitting. I believe mine is a 1/8 NPT though since the line is just a brake line -3AN hose to a -3AN straight swivel on one end and a 90deg. swivel on the other, which is the side I have going into the fitting on the turbo.
