oil cooler to turbo question...
Ok i have a question i have a Oil cooler and im putting a turbo on my car ,, can i run the oil line from the motor to the oil cooler.. and from the oil cooler to the turbo ..It will cool the oil down before it hits the turbo.. Is this possible??
Thanks Guys
Thanks Guys
Re: oil cooler to turbo question... (B18c1CivicTurboed)
the point is to cool it constantly... not jsut for the turbo.. plus thats pointless in a way.. i rather have the cooler oil go in the motor then "just" the turbo.. you tell me which one is worth more... reguardless at the end of that turbo the oil is "HOT"
so we are saying to put the cooler, after an element of the system that is heating the oil? so the engine heats the oil, so does the turbo.
After the turbo would be problematic, because it's a gravity/ drip-drain, I don't believe there is a lot of oil pressure there.
Maybe have a closed loop and mount the oil cooler after the engine. Like with one of the sandwich adapters, have it source and return to the adapter, and then use a 3rd port on the adapter for turbo oil-line feed?
-PHiZ
-PHiZ
EJ1 wilcox
02-05-2005 05:30 PM
