greddy boost gauge install help
Old May 21, 2003 | 06:02 PM
imonkie's Avatar
Default greddy boost gauge install help
what's up guys. i needed a little help with installing my greddy boost gauge. i bought the gauge used so it didn't come with any directions and the greddy site's instructions are very general. i'm installing my gauge on a G3 integra and just wanted any type of instuctions you could possibly give me. thanks.
locations of where the wires are spliced to would be the most helpful. ty
-ivan
Old May 21, 2003 | 07:12 PM
skierGT's Avatar
Default Re: greddy boost gauge install help (imonkie)
go to your fuses. I think theres a ground, 12 volt, and an ignition. wire the ground to any metal on the car, the 12 volt to a constantly on fuse and the ignition to something like your lights if you want the gauge to light up with your lights or to the radio if you want it on with the car or you could use a switch. then run your vacum line to the engine bay and tee off your intake manifold. any line should work. i used the fpr line.
Old May 21, 2003 | 07:13 PM
skierGT's Avatar
Default Re: greddy boost gauge install help (skierGT)
check out this thread too. https://honda-tech.com/zerothread?id=483320
Old May 21, 2003 | 08:43 PM
imonkie's Avatar
thanks for your help skier. i got it working and everything. thanks.
BlackT5
May 25, 2010 11:20 AM
tonyb18b1-T
May 24, 2006 10:01 PM
95excoupe
Aug 17, 2005 09:52 PM
VTC_CiViC
Jun 1, 2002 10:36 PM
zojirushi
May 6, 2002 08:13 AM
