AFC hack question
Old May 23, 2003 | 05:57 PM
ASHY-ELBOW's Avatar
Default AFC hack question
i searched a bit and have not seen anyone with this prob. First off here is the setup ........ 92 hatch,gsr swap, greddy kit ,afc dsm 450's
car runs strong we have it set to 10lbs with a profecb b ,,,fpr with vac off is at 52
car runs fine with just the little hesitation every now and then at around 6k
but here is the thing it will throw a CEL out of the blue once in a great while. The car will just be driving normally not boosting or anything and the light comes on
anyone have this happen? i havent checked the code yet but will in the morning any help would be great thx guys
Old May 23, 2003 | 05:59 PM
CzanSOHC's Avatar
Default Re: AFC hack question (ASHY-ELBOW)
check the code.
Old May 23, 2003 | 06:07 PM
skhonda's Avatar
Default Re: AFC hack question (CzanSOHC)
Could be cel 13 (baro) which will not affect your car at all. Just a guess.
Old May 23, 2003 | 06:15 PM
ASHY-ELBOW's Avatar
Default Re: AFC hack question (skhonda)
yeah im gonna check in the morning ,,,just wanted to post up tonight cuase i will have no spare time tommorow thx guys
Old May 23, 2003 | 06:43 PM
M.A.R.C.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skhonda &raquo;</TD></TR><TR><TD CLASS="quote">Could be cel 13 (baro) which will not affect your car at all. Just a guess.</TD></TR></TABLE>
more than likely that's what it is... i get it occasionally... that and too rich/too lean (code 45)
Old May 23, 2003 | 07:07 PM
Daniel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ASHY-ELBOW &raquo;</TD></TR><TR><TD CLASS="quote">yeah im gonna check in the morning ,,,just wanted to post up tonight cuase i will have no spare time tommorow thx guys </TD></TR></TABLE>
Bah, just do it now and holler back. Stick in a paperclip, turn the key to the II position, and watch the dashboard fireworks. And a CEL 13, like everyone said, is pretty normal with the hack. I never got one, though, because I'm super cool.
Old May 23, 2003 | 08:39 PM
scttydb411's Avatar
cel is probably baro or too rich/lean. have you had your car dyno tuned? i would recommend it immediately. i thought my settings were ok to start...knew they were a little rich for safety, but they were WAY rich. got an extra 22hp on the dyno and rid of any stalling/bogging issues. after driving the car on a trip i also got a hell of a lot more gas mileage.
dyno it!!
Old May 24, 2003 | 09:48 AM
ASHY-ELBOW's Avatar
Default Re: AFC hack question (scttydb411)
k one is cel 3 and teh other is cel 16
i believe he said 3 was for map and 16 is for injector prob
we have the dsm 450's put in with no resistor box. Do u need a resistor box for obd1?
Old May 24, 2003 | 10:07 AM
Racerage1's Avatar
CEL 3 is for your MAP sensor. check your wiring and make sure everything's connected ok.
CEL 16 is fuel injectors. check your wiring of the resistor box. and also, did you get your injectors cleaned and flow tested before you put them in? just some suggestions
Old May 24, 2003 | 10:56 AM
eg6turbo's Avatar
Default Re: AFC hack question (Racerage1)
hahahahhah sorry but hella yeah u need a resistor box man....shoulda did a little more homeowork on the hack....all dsm 450 need a resistor box on them because they are peak and hold injectors and ur car is a saturated type injector from the factory...go to the junkyard and pick one up for 10 bucks....that should clear most of the problems for you...and like racerage1 said...get those cleaned or get new injectors...i had problems with dsm and switched to 440cc instead...no resistor box needed....and also i havnt heard of too many obd1 cars having a cel 13 usually obdII cars....cel 3 check all the wiring for the afc too...just to be sure
Old May 24, 2003 | 11:00 AM
Rpc07's Avatar
Default Re: AFC hack question (eg6turbo)
or you could get 4 resistors from radio shack for a total cost of $1.86 after tax and splice them into the yellow with black stripe wire on the injector clips
-ryan
Old May 24, 2003 | 11:46 AM
hawjdude's Avatar
Default Re: AFC hack question (Rpc07)
I get the cel light once in awhile but nothing is wrong. The tuner told me it was going to happen and it isn't a problem.
crxowner
Oct 12, 2011 02:54 PM
redman223
Jul 13, 2008 01:37 PM
flatline
May 20, 2003 10:58 PM
boostdGS
Jan 28, 2003 06:46 PM
