vafc settings as far as sensor type is concerned
Old May 22, 2003 | 07:59 AM
boosted_dc2's Avatar
Default vafc settings as far as sensor type is concerned
what type of sensor should i be set to??? and why does it say in and then one for out??? thanks for your help
Old May 22, 2003 | 08:01 AM
Adi Radoncic's Avatar
On Fire!
Default Re: vafc settings as far as sensor type is concerned (hooked_up_gsr)
6in 6out for a Gsr I think if thats what you question is..
Adi
Old May 22, 2003 | 08:09 AM
Default Re: vafc settings as far as sensor type is concerned (newgsr)
yes thanks and do you know why my idle is so high its like 1200 with it leaned out 36% on rc 440's??? im running a str 68mm TB and it is completely closed.
Old May 22, 2003 | 08:32 AM
On Fire!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hooked_up_gsr &raquo;</TD></TR><TR><TD CLASS="quote">yes thanks and do you know why my idle is so high its like 1200 with it leaned out 36% on rc 440's??? im running a str 68mm TB and it is completely closed.</TD></TR></TABLE>
Well if you didn't have it set at 6in and 6out before you need to initalize the vafc, take power off of the battery to reset your ecu and than set everything back to where you had it at, if that doesn't fix your idle you have a vacum leak or there is another problem..
I used to have my system leaned out -38% procent at idle on 440's and it ideled fine..
Try that and let me know what happens..
BTW: your egt at 70 should be no more than 1200 degrees
Adi
mark_is_gay
Oct 7, 2005 05:14 PM
onyx00
Nov 23, 2004 10:04 AM
flashmntbiker
Nov 12, 2004 08:43 AM
RuthlessEF-9
Apr 28, 2003 05:10 AM
GSRacer
Dec 12, 2001 04:19 PM
