if u just build ur motor would u ?
i just build my gs-r jrsc motor and white smoke is coming out the valve cover breather is it because the piston rings r not seated yet or did i **** up something also i have the endyn catch can
Re: if u just build ur motor would u ? (Black DC2)
if you used syn blend oil the rings wont seat. Use a Mineral Base 20w50 for 1000 miles then dump it. and you should not boost on the engine till the rings have seated
Re: if u just build ur motor would u ? (cnydelSolHybrid)
i haven't boosted yet only hace 100 miles on the motor it throws out smoke at idle just want to see if this is normal and i used 10w 30 regular oil
kidd_drastic
07-20-2006 04:12 PM
Sassafrass
05-19-2006 04:47 AM
Collateral
03-14-2005 10:39 PM
