Max Daily driven boost?
Old May 20, 2003 | 12:44 PM
I Gotta Question's Avatar
Default Max Daily driven boost?
How much boost could I run daily with a vafc hack and 450cc injectors and a t3/t4 turbo? The engine all stock though.
Old May 20, 2003 | 12:46 PM
liam821's Avatar
25 Year Member
Default Re: Max Daily driven boost? (89_CRX_HF)
Depending on your afc settings...around 10-12psi before you will get a CEL.
liam
Old May 20, 2003 | 01:09 PM
Default Re: Max Daily driven boost? (liam821)
how about if I ran a greddy blue box?
Old May 20, 2003 | 01:27 PM
MyWhiteCivic's Avatar
I run 11 lbs all day. I also have a hondata setup. I would not recommend using the blue box for anything over 7-8 psi.
Old May 20, 2003 | 01:49 PM
15psi of fun's Avatar
Default Re: Max Daily driven boost? (MyWhiteCivic)
im running 9psi all day long on 450 and the hack
Old May 20, 2003 | 06:31 PM
Default Re: Max Daily driven boost? (EFrollingout)
And that's on the stock engine? I'll look into hondata and maybe try the hack. How is your gas mileage? Decent?
Old May 20, 2003 | 07:57 PM
T3T495GSR's Avatar
im tuned on 8psi running the vafc hack on 440cc injectors and my tuner says not to go over 8 psi without race gas or i risk blowing something up
Old May 21, 2003 | 06:56 PM
T3T495GSR's Avatar
Default Re: Max Daily driven boost? (T3T495GSR)
bump
Old May 21, 2003 | 07:02 PM
Soon_2b_evil's Avatar
well i want to know what PSi is everyone using Daily driving?
you think 18psi is to much?
Old May 21, 2003 | 07:17 PM
Chris1091's Avatar
18psi would generally be WAY too much, assuming you're running stock internals.
8psi should be fine as long as you have half-decent fuel settings.
Bimmerman
May 3, 2005 05:51 PM
turbod97ex
Jun 13, 2003 06:44 PM
joeski
May 8, 2003 12:09 PM
b18cya
Feb 24, 2003 07:55 PM
ZCPOWER
Aug 1, 2002 01:44 PM
