Loosing some boost
Old May 23, 2003 | 12:58 PM
BlackB18CTeg's Avatar
Default Loosing some boost
Well I finally am boosting.... However the max boost I get is .24 bar out of a possible .45 bar. Any Ideas where I may be leaking boost? I Quadruple Checked the charge pipes and tightened as much as possbile. One thing that I was thinking that the intake pipe I am usin is 2 1/4 size. Is there not enough air going in? Thanks for any help
Old May 23, 2003 | 01:14 PM
madman604's Avatar
Default Re: Loosing some boost (BlackB18CTeg)
leaky BOV?
Old May 23, 2003 | 01:16 PM
PrecisionH23a's Avatar
did you adjust the wastegate yet?
Old May 23, 2003 | 04:17 PM
Kutsuju_SLeePER's Avatar
Default Re: Loosing some boost (GudeH23a)
How can u adjust the Wastegate. The Spring?
If u adjust the Wastegate, will it maek the BOV not Flutter or Surge either. Im curious cuz mine is doing it.
Old May 23, 2003 | 04:37 PM
Default Re: Loosing some boost (Kutsuju_SLeePER)
Yes, the spring. On the deltagates there is a nut on top of a threaded shaft. Take an allen head wrench and regular wrench to break the nut loose. Screw the allen head shaft till about 1 or 2 threads show with the bolt on. If you still have problems, take the nut off and screw the threads in some more, keep the nut in a safe place if you need it in the future.
Old May 23, 2003 | 04:44 PM
diputs's Avatar
You might try hooking your boost guage and wastegate up to the same vacuum source, if nothing else, you'll be able to see how much boost your wastegate is seeing...
Old May 23, 2003 | 06:57 PM
Default Re: Loosing some boost (diputs)
it is and its reading .24 bar. At one point before BOV and some other stuff I was getting .27 bar and even .35 bar..... It has fluctuated a lot, dunno why
I check BOV, it working fine without leaks, also how do you adjust wastegate, I have TIAL......
Old May 23, 2003 | 07:17 PM
you cant adjust the TIAL. How many T's are you using in a single vacuum source? what are your plugs gapped at?
Old May 24, 2003 | 02:30 AM
i am using plus 4 bosch plugs which cannot be gapped and i have 1 T from fpr and then another T from that T
Old May 25, 2003 | 07:30 PM
bump
anyone?
Old May 27, 2003 | 07:59 AM
bump..... would appreciate ANY help
Old May 27, 2003 | 08:03 AM
twkdCD595's Avatar
could valve overlap cause that much boost to leak out?
I am not familar with the b18c.
richboi
Apr 15, 2007 07:46 PM
b18cEF9
Jul 24, 2005 01:18 AM
japspec
Oct 24, 2003 07:49 PM
AlphaKennyWun
Feb 12, 2002 04:26 PM
DIRep972
Aug 18, 2001 03:34 AM
