compression tester stuck in engine!!
Old May 23, 2003 | 09:13 AM
spacetuna's Avatar
Default compression tester stuck in engine!!
Just like title reads. My compression tester is stuck in one of my cylinders and won't come out. I've twisted the hose until it tore in half. I've tried to use extra long needlenose pliers to get it out. I've sprayed penetrating lubricant. Anyone have any ideas to help out??
Old May 23, 2003 | 10:32 AM
salt's Avatar
Default Re: compression tester stuck in engine!! (spacetuna)
that sux. Mine got stuck in there when I didnt realize there was some kind of adpater on the end of it. I had to grind 1mm of the surface of my 15mm or 16mm socket to get it to fit in the spark plug hole to get it out.
Old May 23, 2003 | 11:03 AM
intekragsr's Avatar
Default Re: compression tester stuck in engine!! (salt)
lol that happened to me. Man I was friken depressed over that **** for like half an hour, until I came to the realization the part stuck in there can be taken out in less than a minute with a damn spark plug socket.
Old May 23, 2003 | 11:32 AM
Toda Party's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salt &raquo;</TD></TR><TR><TD CLASS="quote">that sux. Mine got stuck in there when I didnt realize there was some kind of adpater on the end of it. I had to grind 1mm of the surface of my 15mm or 16mm socket to get it to fit in the spark plug hole to get it out.</TD></TR></TABLE>
lol i did the same thing!
we just coated the tester threads with locktite, scrwed it back into the adapter that was stuck down there, waited, and it unscrewed out after 15 min
Old May 23, 2003 | 11:52 AM
Scott - 93HB Si's Avatar
Default Re: compression tester stuck in engine!! (Toda Party)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toda Party &raquo;</TD></TR><TR><TD CLASS="quote">
we just coated the tester threads with locktite, scrwed it back into the adapter that was stuck down there, waited, and it unscrewed out after 15 min</TD></TR></TABLE>
I had to pull my head cuz no socket would fit on my adapter.
then I just put a big screwdriver into the adaper from the CC side and screwed it out the top.
Old May 23, 2003 | 11:54 AM
canuck-mx6's Avatar
Default Re: compression tester stuck in engine!! (Scott - 93HB Si)
I managed to use a deep 16 mm socket to remove the end of the compression tester which got stuck in my friends motor while I was doing a test for him.
Old May 23, 2003 | 12:08 PM
silverEH2's Avatar
Default Re: compression tester stuck in engine!! (canuck-mx6)
pulling the head would be my last resort
Old May 23, 2003 | 12:20 PM
spacetuna's Avatar
Thats what happened to me as well. The adapter was stuck in the engine so I took lock tite and screwed the hose back into it so I could twist the hose to get it out. Well, it's in there too tight and just twisting the hose won't get it out. And since the hose is sticking out of the middle of it I can't use any type of sockets to get it out since the hose is in the way.
Old May 23, 2003 | 12:32 PM
SiRkid's Avatar
roflmao.
its a conspiracy!
damn compression tester makers. they are out to fug us over
Old May 23, 2003 | 01:15 PM
MachAF's Avatar
Default Re: compression tester stuck in engine!! (SiRkid)
Same thing happened to me. I don't use that damn adapter thingy anymore. I was able to twist the hose in tight enough agian and get both to unscrew, lucky me.
Try the spark plug socket.
Old May 23, 2003 | 01:20 PM
PrecisionH23a's Avatar
Default Re: compression tester stuck in engine!! (MachAF)
also spray a little wd-40 into there, that helps. If you dont care about the adapter, take a flathead to the hole part of the adapter, bang it with a hammer, then unscrew it. you'll most likely need a new adapter after this. be careful.
Old May 23, 2003 | 07:50 PM
M.A.R.C.'s Avatar
Default Re: compression tester stuck in engine!! (GudeH23a)
this post is hilarious... i feel so much better knowing i am not the only one this has happened to... i got the lil adapter part stuck in mine too. i was freaking out. bought two handy needle nose pliers because of it. and i called my friend over and he just took one try at it with the tester hose and got it right out... that bish.
Old May 23, 2003 | 08:10 PM
Muckman's Avatar
Moderator in Chief
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MachAF &raquo;</TD></TR><TR><TD CLASS="quote">Same thing happened to me. I don't use that damn adapter thingy anymore. I was able to twist the hose in tight enough agian and get both to unscrew, lucky me.</TD></TR></TABLE>
lol Same thing here, was scared but got lucky was able to carefully get it out.
Youd think they'd improve that part...
Old May 23, 2003 | 09:12 PM
phresh_5's Avatar
Happened to me too. I screwed the adapter to the tester super tight before I put it in so it wouldn't leave the adapter in there. Well now the whole tester is stuck in there and I've tried twisting the hose till it almost broke. So I decided to put two cap fulls of oil down the spark plug hole and wait untill the engine was cold. I then came back 2hrs later with really long needle nose plyars and put them down the hole and twisted it out.
Old May 23, 2003 | 09:57 PM
shortyz's Avatar
Default Re: compression tester stuck in engine!! (phresh_5)
uhm how tite are you guys putting those ******* things in. ive done loads, its a brass tapered thread it doesnt have to be torked.
lol
Old May 23, 2003 | 10:41 PM
Drew Peacock's Avatar
Default Re: compression tester stuck in engine!! (shortyz)
I had the same thing happen 3 times Long needle nose pliers should do it??
gjbraun
Jun 18, 2012 10:57 AM
DFW
29
Mar 23, 2007 05:47 AM
NegativeXero
11
Aug 18, 2006 06:52 PM
Teg4e
Jun 29, 2006 02:24 PM
scartail
Aug 17, 2005 06:26 PM
