Nitrous Oxide Injection - A form of Forced Induction, or not ?
Old May 22, 2003 | 01:42 PM
Matt Sterbator's Avatar
Default Nitrous Oxide Injection - A form of Forced Induction, or not ?
Feel free to explain your answers. Thanks
Old May 22, 2003 | 01:50 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: Nitrous Oxide Injection - A form of Forced Induction, or not ? (Matt Sterbator)
not really something you need to poll. its a fact.
Old May 22, 2003 | 01:56 PM
racerxadam's Avatar
its one of those things that will always be debateable, like should abortion be legal. make up your own mind and leave it at that.
Old May 22, 2003 | 02:36 PM
bottlefedb18c1's Avatar
in a way it is and in a way it is not becouse say i am looking for a nice N/A nitrous cam and it is getting to be hard to find info on
and turbo there is different carectoristcs say like you drop cr number with turbo MOST of the time and with spray you can go up
Old May 22, 2003 | 02:45 PM
RyanEJ8's Avatar
Forced induction is forcing additional air in the cylinders in order to burn more fuel. This is exactly what a turbo, supercharger, AND nitrous does. Nitrous goes into the cylinder and the 2 parts nitrogen is burned off leaving the oxygen molecule. Additional air into the cylinders. This is why I say it's BS when someone calls nitrous "cheating", when it works on the same basic principle as a turbo.
Old May 22, 2003 | 02:47 PM
yes that is true but you dont see anyone saying oh i am going to drop my compretion but i dont know how far becouse i dont want to hurt the spool time on my bottle
there is differances but not much i do agree with you though
Old May 22, 2003 | 03:02 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matt Sterbator &raquo;</TD></TR><TR><TD CLASS="quote">Feel free to explain your answers. Thanks</TD></TR></TABLE>
nitrous is pushing more air into the engine, you do the same with compressor, except you compress the air.. both methods allow more air into the engine.
Old May 22, 2003 | 03:04 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: Nitrous Oxide Injection - A form of Forced Induction, or not ? (vtec.dc2)
INJECTion. Of course.
Old May 22, 2003 | 03:13 PM
GSRwBOOST's Avatar
Default Re: Nitrous Oxide Injection - A form of Forced Induction, or not ? (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">Forced induction is forcing additional air in the cylinders in order to burn more fuel. This is exactly what a turbo, supercharger, AND nitrous does. Nitrous goes into the cylinder and the 2 parts nitrogen is burned off leaving the oxygen molecule. Additional air into the cylinders. This is why I say it's BS when someone calls nitrous "cheating", when it works on the same basic principle as a turbo.</TD></TR></TABLE>
actually they seperate with the heat, the oxygen helps the combustion cycle and the other leftovers help control the combustion process...
Old May 22, 2003 | 03:36 PM
RyanEJ8's Avatar
Default Re: Nitrous Oxide Injection - A form of Forced Induction, or not ? (GSRwBOOST)
When you say, "oxygen helps the combustion cycle", you mean it is used to burn the extra fuel, correct? This is the same thing I was trying to say.
Old May 22, 2003 | 06:01 PM
95c1v1cs1's Avatar
This is not 95c1v1cs1 speaking-- this Message is from Integranator:
With nitrous, you're not really "forcing" air into the cylinders. You do happen to be adding more air molecules though, but not forcing air into them. With boost, you are pressurizing (sp?) the air to squeeze, or "force" the air into the cylinders. You're not just place more air into the cylinders like nitrous does.
Oh yeah-- It also helps if you decide whether or not to take the literal meaning of the words, or just the understood meaning of the phrase.
Old May 22, 2003 | 06:52 PM
Default Re: Nitrous Oxide Injection - A form of Forced Induction, or not ? (95c1v1cs1)
Well Nitrous IS injected into the intake (which IS part of the engine). While it's not "forced" into the cylinders, rather it's sucked in there, it's still forced into the engine. The engine still receives more oxygen than it can get on it's own without the nitrous.
So basically, like I said before, there are two trains of thought here. Either you consider it forcecd induction because it adds more oxygen to the motor than it can get on it's own... or you only consider something forced induction if it pressurizes the intake.
As far as I've seen, and I've had this argument ALOT in the past week, is that there is NO set definition of the term "forced induction". There are websites that classify nitrous as forced induction, and there are some websites that list forced induction AND nitrous. So far I haven't seen anything explaining how it ISN'T forcecd induction.
Old May 22, 2003 | 09:48 PM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95c1v1cs1 &raquo;</TD></TR><TR><TD CLASS="quote">This is not 95c1v1cs1 speaking-- this Message is from Integranator:
With nitrous, you're not really "forcing" air into the cylinders. You do happen to be adding more air molecules though, but not forcing air into them. With boost, you are pressurizing (sp?) the air to squeeze, or "force" the air into the cylinders. You're not just place more air into the cylinders like nitrous does.</TD></TR></TABLE>
hmmmmmm......950-1000psi in a bottle? If you ask me I would say it's pretty pressurized, not just "placed" into the cylinders.
Old May 22, 2003 | 11:36 PM
*Boostwerks*'s Avatar
If it's not "naturally" inducing ambient air, it's labled as forced induction.
Hence yes it is a form of forced induction. just like what motormatrix said. it's a fact.
Old May 22, 2003 | 11:59 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Nitrous Oxide Injection - A form of Forced Induction, or not ? (Bryson)
Think of Nitrous oxide as forced aspiration. It doesn not compress air molecules like a turbo or a SC would, but it does force oxygen into the cylinders.
Forced Induction= boost, psi, turbo, SC
Nitrous oxide= forceing oxygen without pressure.
art
Old May 23, 2003 | 12:01 AM
senpai's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">If it's not "naturally" inducing ambient air, it's labled as forced induction.
Hence yes it is a form of forced induction. just like what motormatrix said. it's a fact.</TD></TR></TABLE>
I concur.
Old May 23, 2003 | 06:37 AM
but it is not like you are going to have 950-1000 psi of pressure in the intake manofld it is regulated to a lower psi during the injection
Old May 23, 2003 | 07:23 AM
RyanEJ8's Avatar
Default Re: Nitrous Oxide Injection - A form of Forced Induction, or not ? (bottlefedb18c1)
I don't think that the solenoids regulate the pressure though. It's still going to be at 950psi when it comes out of the fogger. After that it's a different story though, I'm not sure how much pressure is lost in the intake manifold.
Old May 23, 2003 | 08:06 AM
the pressure drops after it comes out of the jet thats why it is there it is like saying you are running open solennoids
Old May 23, 2003 | 08:12 AM
Mike D's Avatar
Default Re: (bottlefedb18c1)
It is a fact, all three add more oxygen.
Out the three, nitrous oxide does it more efficiently.
Mike
Old May 23, 2003 | 08:28 AM
RyanEJ8's Avatar
Default Re: (Mike D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike D &raquo;</TD></TR><TR><TD CLASS="quote">It is a fact, all three add more oxygen.
Mike</TD></TR></TABLE>
Yes nitrous is the most efficient.
Old Jun 5, 2003 | 09:17 AM
94TealGSR's Avatar
I think Forced Induction refers to SC's and Turbos. I think art put it right with the term 'forced aspiration'. The three should be grouped together, but forced induction isn't the term that should be used.
Old Jun 16, 2003 | 09:06 PM
94dxt's Avatar
Default Re: (94TealGSR)
"nos" definetily isn't naturally aspirated but you aren't forcing air into the motor so it's not FI. But call it what you want.
Old Jun 17, 2003 | 01:08 AM
lazerus's Avatar
Default Re: (94dxt)
you willingly force a substance not present in the air, into the combustion chamber.
This constitues forced induction.
technically water/alky injection is forced induction, and so is propane injection :-)
Old Jun 17, 2003 | 04:23 AM
symba's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94TealGSR &raquo;</TD></TR><TR><TD CLASS="quote">I think Forced Induction refers to SC's and Turbos. I think art put it right with the term 'forced aspiration'. The three should be grouped together, but forced induction isn't the term that should be used.</TD></TR></TABLE>
This is the best answer I've seen so far. I consider it forced induction for lack of a better term to describe it. There are only 2 terms out there...F/I or N/A..Certainly doesn't belong in N/A, that would be BS.
guessohw
Jan 12, 2009 07:39 AM
AKaccord
Apr 28, 2004 10:20 PM
Legendaryyaj
Nov 18, 2003 02:26 PM
Muckman
Nov 21, 2001 10:28 AM
