Use smaller brakes for more acceleratiion?
as title says:
If I were to put some smaller/lighter discs on my car, would my ETs be lowered?
as with using lightweight wheels and flywheels, its all part of the rotating assembly.
or it this a waste of time? and or dangerous. ?
Re: Use smaller brakes for more acceleratiion? (Turbo E)
When it comes to brake rotors, I think the gains are miniscule. So miniscule that the safety sacrifices you would have to make wouldnt be worth it.
The difference in wieght between a 12" rotor and a 10" rotor are very small.
Re: Use smaller brakes for more acceleratiion? (Shift!)
ya, the only way i see you dropping times from lighter brakes is to remove them alltogether, stupid of coarse. it would be like pulling your e brake to stop everywhere, which as fun as it sounds IS a bad thing.
or if you want to spend the money, carbon brakes are a lot lighter and stop better from high speeds, but a set up costs about as much as a used honda
Re: Use smaller brakes for more acceleratiion? (Phoenix GSR)
damn, i bet you stop pretty quick, is it possiable to warp those? that sure would suck. who makes them?
06 Habanero-NaVi
Honda Civic (2006 - 2015)
01-30-2007 04:05 PM
