what spark plugs to run
Old May 23, 2003 | 03:40 PM
TurboBumblBee's Avatar
Default what spark plugs to run
i have drag three kit b18c motor 440cc injectors dig 6 msd and various other **** what spark plugs should i run at the moment i have platium serius but i think i should be running a colder plug than these any input please thanks
Old May 23, 2003 | 04:01 PM
madman604's Avatar
Default Re: what spark plugs to run (Hybrid95CivicEX)
like everyone else here NGK BKR7E
Old May 23, 2003 | 06:07 PM
ladysman's Avatar
Default Re: what spark plugs to run (Turbo E)
https://honda-tech.com/zerothread?id=510127
Old May 23, 2003 | 06:20 PM
psi420's Avatar
Platinum plugs retain more heat than copper.
YOu are not doing your motor any good by running those.
BKR7E for all F/I, NOS apps.
Old May 23, 2003 | 08:18 PM
sweet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E &raquo;</TD></TR><TR><TD CLASS="quote">like everyone else here NGK BKR7E</TD></TR></TABLE>
F/I setups normally use these copper NGK plugs.
Old May 23, 2003 | 08:24 PM
PrecisionH23a's Avatar
Default Re: what spark plugs to run (sweet)
ngk brk7e-11s part number 1263 (gap .045) at advanced auto parts... 6097 is the same plug with a smaller gap size, i believe .035
It doesnt matter which one you get, you can always gap them yourself.
Old May 24, 2003 | 06:56 AM
ladysman's Avatar
Default Re: what spark plugs to run (GudeH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GudeH23a &raquo;</TD></TR><TR><TD CLASS="quote">ngk brk7e-11s part number 1263 (gap .045) at advanced auto parts... 6097 is the same plug with a smaller gap size, i believe .035
It doesnt matter which one you get, you can always gap them yourself.</TD></TR></TABLE>
The gap isn't the only difference. The 6097 has the V-Power electrode as well. See here for more info https://honda-tech.com/zerothread?id=510127
Old May 24, 2003 | 08:03 AM
Default Re: what spark plugs to run (ladysman)
i was told the gap was the only difference, i found that strange. thank you for clearing that up for me
Old May 26, 2003 | 04:26 PM
Burke's Avatar
Banned
i have an extra set of bkr7e's that i'll sell for 12 shipped if anyone wants them or cant find them locally
later
Old May 26, 2003 | 04:36 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Old May 26, 2003 | 05:03 PM
glagola1's Avatar
Default Re: what spark plugs to run (SIXTYdashONE)
Everybody says to run the BKRE7's but the problem with those is that when you gap them to .028 or so it puts too much angle on the grounding bit and that's bad. Plus the v groove in the electrode is a hot spot.
I've found the BCPR7ES plugs are gapped a good bit closer stock and that when you close the gap to .028 the grounding strip is more horizontal to the electrode and they don't have a V in them to create the detonation inducing hot spot.
The BCPR7ES is the plug to run.
Old Aug 29, 2003 | 01:05 PM
vtec.dc2's Avatar
Default Re: what spark plugs to run (glagola1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by glagola1 &raquo;</TD></TR><TR><TD CLASS="quote">Everybody says to run the BKRE7's but the problem with those is that when you gap them to .028 or so it puts too much angle on the grounding bit and that's bad. Plus the v groove in the electrode is a hot spot.
The BCPR7ES is the plug to run.</TD></TR></TABLE>
BCPR7ES - is that ngk number? i never heard of these.
Old Aug 29, 2003 | 01:11 PM
swlabhot's Avatar
Don't mean to jack thread. Just been checking out some Nology's products. What about their Silverstone plugs? They say they use silver instead of copper and its a better conductor than copper and so will create a stronger spark.....
Old Sep 1, 2003 | 11:01 AM
So who here runs the NGK 6097's?
lifes_simple
Honda Civic (2001 - 2005)
Aug 21, 2007 06:23 AM
OneCrzySetup
Nov 17, 2006 11:53 AM
Phatch99
Sep 8, 2005 12:39 PM
hybrid_vtec
15
Jul 30, 2004 01:37 PM
blackccoupe
Mar 31, 2004 02:50 PM
