i NEED HELP...looking horrible with sputtering
Old May 22, 2003 | 12:39 PM
btole's Avatar
Default i NEED HELP...looking horrible with sputtering
alright this is really starting to make me mad
i had a sputtering issue with my car from 15-3000rpm range, so and people were telling me that it was becuase i was running to rich. i did a search on the AFC hack cuase thats what im using and came to this page:
https://honda-tech.com/zero...37901
i used these setting for my partial throttle
1-4k = -40%
4.5k = -37%
5k = -33%
5.5k-9k = -30%
the sputtering went down a little but not completely but now the car will not idle. it goes from 640-790rpms, and it will die on me when i come up to a light.
my WOT is set to 1-5k = -35% and 5.5 - 9k = -36%
im running 440 injectors, no fmu and and intank. fuel is set at 40 psi in idle and i gapped the plugges to .30.
any help would be great.... accept the usual get a hondata. i know im saving but i want to be able to drive this for right now and not pop at every stop light.
also i was reading about keeping the car out of open loop (i think) can this be done and would it make the car run better?
Old May 22, 2003 | 01:17 PM
Mr. Softee's Avatar
Default Re: i NEED HELP...looking horrible with sputtering (btole)
do you have the s-afc setup/installed right? friend of mine just had a similar problem
Old May 22, 2003 | 02:03 PM
btole's Avatar
ya i have tripple checked the wires
map--> tps
Old May 22, 2003 | 02:51 PM
btole's Avatar
Default Re: (btole)
ok so i think my problem occurs when i go into open loop... is there a way of stopping this from happening? when it occurs the car wants to run in stoich instead of rich... when this happens it starts to sputter.
Old May 22, 2003 | 03:47 PM
btole's Avatar
Old May 22, 2003 | 05:43 PM
btole's Avatar
bump
Old May 23, 2003 | 08:52 AM
btole's Avatar
anyone?
Old May 23, 2003 | 09:21 AM
JalopySiR's Avatar
Default Re: (btole)
There is your problem. You are supposed to install the AFC according to the instructions. There is no "HACK" involved. The -% settings limit the map sensor voltage. Brilliantly simple. Install AFC correctly=fix problem
Edit: I forgot to quote post "MAP ==> TPS"
Discosteak
Sep 9, 2005 08:13 AM
ExVtec
May 16, 2004 07:48 PM
eg2_RE
Nov 22, 2003 11:15 PM
CBR600OnTop
Feb 28, 2003 09:54 PM
deacs
Sep 20, 2002 12:26 PM
