Engine Balancing Questions
Old May 22, 2003 | 10:02 AM
Bnjmn's Avatar
Default Engine Balancing Questions
I'll be starting a rebuild shortly and the first step will be getting the rotating assembly balanced. I don't think any place in the area does anything except mostly domestic work- is there anything special that I should tell them?
Also, what exactly should I give them for balancing?
Rods
Pistons
Crank
flywheel
clutch
crank pulley
anything else?
Thanks-Ben
Old May 22, 2003 | 11:58 AM
GreddySi99's Avatar
Default Re: Engine Balancing Questions (Bnjmn)
give the machine shop all of the rotating assy. the pistons should be balanced from the manufactures within 1 gram of each other. the rods should be within a gram and then the crank should be balanced as well. with all that done you should be fine
Old May 22, 2003 | 01:53 PM
niedejb's Avatar
Default Re: Engine Balancing Questions (intercooledJRSC)
My balancer wanted everything in your list and....:
Wrist Pins w/clips
Rod Bolts
Timing Belt Pulley (one on the crank)
Pressure Plate (w/bolts)
Flywheel Bolts
Propulsion
Nov 26, 2003 06:54 AM
maddog20
Oct 29, 2003 03:00 AM
1.8T_EG
Feb 7, 2003 12:51 PM
H22Chameleonaccord
Jan 14, 2003 02:17 PM
2K_TEG
Jun 30, 2002 10:15 AM
