Wastegate Question
Old May 23, 2003 | 12:33 PM
ELSpool's Avatar
Default Wastegate Question
I have a T3/TO4E on an D16Y8. AFC Hack for managment, 2.5 inch DP, highflow cat and 2.5 inch exhaust. The gate on this turbo is internal and I only run 9psi. Boost doesn't hit full till 4700rpm. Teh gate seems to be partically always open because the actuator was meant to run bigger boost, so setting the spring for 9 psi is nothing. I'm wondering if I should put on a smaller actuator from a small turbo to keep the gate closed more for better spool, or try a MBC to see if that works?
Old May 23, 2003 | 01:13 PM
madman604's Avatar
Default Re: Wastegate Question (HiRolla)
Go MBC. itll help
B6tPoweredMx3
Jun 19, 2005 06:41 AM
vr6mole
Jun 6, 2005 11:16 AM
s1ngle
Sep 29, 2004 01:50 PM
'99luder
Jul 31, 2004 07:26 AM
ninja8oi
Feb 9, 2004 02:18 PM
