is 550cc rc saturated injectors good for boosting at 6-10 psi??
i am about to buy 550cc injectors good for stock internal boost at 6-10psi on a 2000 GSR...i wanted to know if that is too much fuel or will it be ok...thanks let me know
Re: is 550cc rc saturated injectors good for boosting at 6-10 psi?? (adhana2)
uhhh, you're using fuel management right...that's exactly what it does "manage the fuel"
also it depends on the hp #'s mostly, compared to the psi you'll be running, 550's should get you 350-400whp range.
Re: is 550cc rc saturated injectors good for boosting at 6-10 psi?? (98civicEX)
naw i am goin to use a safc hack and a 255lp fuel pump but not fmu ...i was rangin about 260-280whp... i think these injectors r goin to be 2much...shud i go with 440cc instead?
Re: is 550cc rc saturated injectors good for boosting at 6-10 psi?? (Sonny)
Save your $$ on the RC's. IM viren, hes selling delphi 550's for 200a set. Thats prob what your paying for 1 RC.
Re: is 550cc rc saturated injectors good for boosting at 6-10 psi?? (BoostedGSRBubble)
they arnt saturted sorry...does viren have any 440's for sale?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98civicEX »</TD></TR><TR><TD CLASS="quote"> uhhh, you're using fuel management right...that's exactly what it does "manage the fuel"
also it depends on the hp #'s mostly, compared to the psi you'll be running, 550's should get you 350-400whp range.</TD></TR></TABLE>unless using an FMU, with which 440s can get you 450-475 WHP
Re: is 550cc rc saturated injectors good for boosting at 6-10 psi?? (hybridvteceg)
but i can run 550cc with 6psi and it will be fine? cuz i dont wanna screw up my motor by gettin too much fuel in there...some1 told me it will mess my motor up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adhana2 »</TD></TR><TR><TD CLASS="quote">but i can run 550cc with 6psi and it will be fine? cuz i dont wanna screw up my motor by gettin too much fuel in there...some1 told me it will mess my motor up</TD></TR></TABLE>
of course, you just need to limit the % duty cycle
oh aite thatz tight... cuz i am gettin a badass deal on the 550's...thanks 4 all the help? reely helped me out
