Anyone ever spin a bearing from running to rich?
Can this happen? A friend of mine was telling me that you could spin a bearing from running to rich, how does this happen assuming oil isn't a factor and it is filled to factor spec? Is it that the rich fuel mixture thins the oil out?
Re: Anyone ever spin a bearing from running to rich? (bxsi)
In theory, it could happen if you were running rich enough, but you would have to be so rich you'd be smoking black smoke constantly, vehicle would barely run, and would have to be like that for a long time.
Re: Anyone ever spin a bearing from running to rich? (Jared)
If you had 4 quarts of oil and 4 quarts of gas in your pan...maybe, but that is near impossible
Re: (earl)
Well actually I know of a guy tht had a built H22A with FMAX kit and shitty MF2 on it that was overfueling, it coul've been because of a faulty map sensor , I will find out. ut he overfueled it so much he washed the walls down and thrust washers!
Blazin Si
19
06-26-2005 08:59 AM
