max boost with this setup (new car im buying)
Old Jul 3, 2003 | 09:13 PM
oMek's Avatar
Default max boost with this setup (new car im buying)
well im gona buy this 95 integra fully built with 2500 on motor here are my specs any idea what my 1/4 mile time will be, and also what would be best turbo to add, or more whats max boost this could handdle
Head:
JUN valve springs
JUN titanium retainers
Professionally ported and polished
Titan Motorsports adjustable cam gears
JG Edelbrock intake manifold
Ferrea Valves (stock size)
Stock cams
Engine:
Sleeved
Arias 9.5:1 CR pistons (stock bore)
Eagle ESP H-beam rods
Stock crank (knife-edged)
Professionally balanced
Transmission:
Spoon tranny w/ LSD and 4.8 Final Drive
ACT 6 puck unsprung race clutch
ACT extreme pressure plate
Fidanza aluminum flywheel
Other:
Apexi VAFC
B&M short throw shifter
Erebuni carbon fiber hood (unique)
Sparco Hood Pins
Energy Suspension polyurethane motor mounts
MSD SCI ignition box (uninstalled)
MSD Distributor (uninstalled)
MSD Blaster 2 coil (uninstalled)
Autometer full pillar (uninstalled)
Autometer Phantom electric oil pressure gauge (uninstalled)
Autometer Phantom EGT w/ sending unit (uninstalled)
Autometer Phantom Boost Gauge (uninstalled)
Walbro 255lph intank fuel pump (uninstalled)
AEM cold air intake
Honda speed lowering springs
Custom 2.25" cat back exhaust w/ DTM muffler
2 14" wheels w/ BFGoodrich drag radials
New Kumho 711 series tires (200 miles)
Old Jul 3, 2003 | 10:16 PM
oMek's Avatar
Default Re: max boost with this setup (omekone)
no ideas about max boost levels?
Old Jul 4, 2003 | 02:09 AM
pissedoffsol's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by omekone &raquo;</TD></TR><TR><TD CLASS="quote">no ideas about max boost levels?</TD></TR></TABLE>
how? you never mention a turbo once.
15 psi on a t23123123 = 213124123312 hp
15 psi on a t10 = 56 hp
obviously i've exadgerated this.... but see the point?
Old Jul 4, 2003 | 05:37 PM
oMek's Avatar
Default Re: max boost with this setup (pissedoffsol)
i havent got the turbo yet, all this car needs is furl managment and injectors, and a turbo right??? im wondering whats the best kit to buy to get max hp, ide like to know can this set up handel 20 lb boost? (track only of corse)
Old Jul 4, 2003 | 06:23 PM
delslow94's Avatar
why run the jun valvtrain with just stock cams. there is no need and its just extra stress on the cam when it spins.
Old Jul 4, 2003 | 09:40 PM
Type-GS-R-Turbo's Avatar
When you buy a car like that, 99% of the time, you're only buying someone else's problems. However if you do get a good deal, you're probably looking at mid 12's on 15 psi.
I have 8.8:1 CR on my GS-R engine so I figure I can run about 18 psi and I'm aiming for low 12's. I haven't run my car on the track, I have no timeslip, I'm just guestimating.
Old Jul 5, 2003 | 12:41 AM
oMek's Avatar
Default Re: max boost with this setup (Type-GS-R-Turbo)
ya guy said it needs a knock sensor, hb need paint, need new fender and paint, body has 182k motor has 2k since rebuild he clames, he also said it hasent bin tuend since the motor was built. i am willing to invest some $, i just hope i didnt get a lemon
Old Jul 5, 2003 | 12:43 AM
oMek's Avatar
he also said he has a half done turbo kit for this car, only need some pipes and intercooler. maby i sould buy that also
nodnarb660
Jul 17, 2012 08:38 PM
ilovemyh22
May 26, 2009 08:14 PM
ludicrisprelude
May 30, 2004 08:59 PM
oMek
Jul 3, 2003 01:59 AM
DamonBoost
Jul 9, 2002 06:44 AM
