MICROTECH STAND ALONE???
Old Jul 2, 2003 | 05:22 PM
fernancivic's Avatar
No Sales Forums
Default MICROTECH STAND ALONE???
I JUST BOUGHT A MICROTECH AND I WAS WONDERING IF ANYONE HAS ANY EXPERIENCE (KNOWLEDGE) GOOD OR BAD OR ANY COMMENTS AT ALL ABOUT IT.
Old Jul 3, 2003 | 01:58 AM
flipsta's Avatar
a friend of mine runs a microtech on his turbo'd d16a8 crx and just ran an 11.73 so he is happy with it.
Old Jul 3, 2003 | 03:52 PM
No Sales Forums
Default Re: (flipsta)
nice
Old Jul 3, 2003 | 04:11 PM
ucacrx's Avatar
Default Re: (AllVersionSi)
i run a MicroTech MT8 & there a tops stand-alone ECU
sup Flips
Old Jul 3, 2003 | 05:20 PM
poid's Avatar
Default Re: (ucacrx)
They arent a bad ECU, but they've received criticism from some users for having a not quite tunable enough map (ie can get the car running good but not great). Then again other users reckon its great.
I'll say make sure the tuner is up to the task. I'd choose haltech over it though
Old Jul 3, 2003 | 07:27 PM
DRAGLS's Avatar
Default Re: MICROTECH STAND ALONE??? (AllVersionSi)
I tuned two of my friends microtech very user friendly if u need any help i live in orlando also
p.s. badasss system
Old Jul 3, 2003 | 07:29 PM
freakie's Avatar
microtech are good, but teh tuning resolution points are quite rough and limited, hence sum ppl say its not runing quite right. For the money tho, they are good systems, but they are not the best for fuel consumption.
Old Jul 4, 2003 | 06:19 PM
gsrt2c's Avatar
what price do they run and are they obd2 compatable?
Old Jul 5, 2003 | 08:48 AM
No Sales Forums
Default Re: (gsrt2c)
they run about 1100 and i bought one for myself to run on my 99 civic si. a friend of mine is running it on his 00 gsr and the car is running perfect. after his install u cant even tell its running stand alone.
Old Jul 5, 2003 | 10:17 AM
Blueprint's Avatar
Micro-tech has been used widely in the RX-7 scene. I have heard few piston guys using them. oh and just becasue you have a stand alone doesnt mean that the car wont idle or stuff like that. I have seen alot of cars on stand aolne on the street too and you cant tell etiher.
Old Jul 5, 2003 | 11:19 AM
freakie's Avatar
Default Re: (Blueprint)
like all computers, the tuner is key. It can run like factory or it cna run like crap depending on the tuner.
I've found microtech to be quite good. But for an extra 300 USD or so, Id rather go the Autronic SMC. The Rx7 scene widely uses this computer because ppl said that the tuning point is too limited for piston motors. Again all up to the tuner.
Old Sep 3, 2003 | 11:02 PM
10sec_rx7's Avatar
Default Re: (freakie)
Freakie,
the tuning points are identical to a e6k haltec, so saying that is pointless, they come with a inbuilt 2.5 bar map sensor good for 20psi and have a optional 3 bar map sensor, rpm points every 500rpm to 9000rpm, can control your vtec no problems at all, come with a base map to suit your motor, if you get a LTX8 you can run DFI to get more spark!
Dale
Old Sep 4, 2003 | 03:22 AM
poid's Avatar
Default Re: (10sec_rx7)
Maybe with the newer ones, with the older Microtech's its well known that they are more suited to drag cars that go open throttle virtually non-stop and rotaries. Hence fuel consumption was compromised in many applications.
However as i said before they arent bad ECU's and with a good tuner can run well, especially their newer ECU's.
Old Sep 4, 2003 | 03:23 AM
GimpyAccord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 10sec_rx7 &raquo;</TD></TR><TR><TD CLASS="quote">Freakie,
Dale
If what you say is true (rpm points 500-9000 at every 500rpm interval) this ecu has greater resolution than a stock honda ecu. So saying its not 'tunable enough' would be innaccurate and I would blame the guy tuning.
Old Sep 4, 2003 | 04:08 PM
10sec_rx7's Avatar
the older ecus had one load and idle map with rpm corrections, they worked fine for street cars when they were tuned right, most tuners didnt set the corrections,
the current LT series have load points every 500rpm and the new series will have user denfinable everything,
there are plenty of hondas here running the microtechs with out any problems at all,
Dale
juiced2ndgenteg
Engine Management and Tuning
Oct 27, 2012 10:25 AM
Projectludatic
Mar 5, 2010 05:50 AM
GEN2 LS
May 19, 2008 08:29 AM
MR_FIX_IT
Sep 20, 2006 04:01 PM
turbo98lude
Jul 7, 2005 02:40 PM
