Skunk cams in a Turbo setup
Old Jul 1, 2003 | 11:37 AM
turbo*s2k's Avatar
Default Skunk cams in a Turbo setup
Just curious if anyone is running skunk cams in their turbo setup... I have a set of skunk stage 1 cams that I used in my all motor setup, but now I'm not sure if I can use them with my turbo setup.
I also have set up Type R cams that I can use. Which would you recommend?
Modified by TurboChrgd_Civic at 12:47 PM 7/1/2003
Old Jul 1, 2003 | 11:45 AM
BoostedsiR's Avatar
Default Re: Skunk cams in a Turbo setup (TurboChrgd_Civic)
you want gsr cams they have a perfect lift on boosted cars thoose cams have a fucked up duration time for boosted cars but N/A that is how you make power, you acould run your setup like that but when you switch your cams out with something stock or turbo cams you will be very happy
Old Jul 1, 2003 | 12:07 PM
quikB18B's Avatar
Default Re: Skunk cams in a Turbo setup (BoostedsiR)
Sell the skunk cams, get some gsr cams and put your xtra $ elsewhere.
pitchblacksol
Aug 23, 2005 02:30 PM
WannabeEF9
Jan 4, 2005 03:54 PM
wrXtian
Mar 9, 2003 06:07 PM
