2.0L Stroker kit for JRSC GSR?
Would it be worth the money to stroke my 1.8 to a 2.0L using the stock81mm bore,
And then leave the SC on it running 10psi?
How much more power could I make by adding the 2.0L stroker?
If anyone has any experience with using a stroker kit, Please give me the ups and downs of it.
Thanks.
Thanks.
Re: 2.0L Stroker kit for JRSC GSR? (speedy108)
I read something earlier about the rod ratio being altered with these stroker kits that messed up the engine, IDK, but thats what I read. You would get decent gains from the kit, but the real reward is that you can now up the boost on your blower a whole lot and safely spray alitte n2o with some tuning.
gmoore
gmoore
Re: 2.0L Stroker kit for JRSC GSR? (theory48)
Why would you sleeve a Non-VTEC block when you can sleeve a VTEC block and yield the same results. B18C to 84mm is a good choice.
Re: 2.0L Stroker kit for JRSC GSR? (Quik Chris)
Thank you Quik Chris, There is no point in sleeving a LS or CRV block when he has a GSR block already. In case everyone hasn't noticed there is a reason that all the fast hondas use a Vtec block to start. CUASE THEY ARE BETTER!!!!!!!!!!
Re: 2.0L Stroker kit for JRSC GSR? (turboDC2)
I was offering you some good advice with a supercharged set up, The LS or CRV block sleeved will make more power, It has a longer stoke ( More torque)
You are some what limited with the blower , ( Boost wise) That's why you need the biggest motor you can get.
I have built alot of supercharged vehicles, I know what makes power.
Just trying to help.
When you've sleeved your GSR, Lets see what power you make( Let see if it is BETTER)
Re: 2.0L Stroker kit for JRSC GSR? (intercooledJRSC)
Cylinder walls can handle more boost / pressure when block is sleeved.
Stroker kits in a boosted motor can spin the rod bearings easier.
crakteg
09-28-2008 05:25 PM
VtecKiDD
01-12-2004 07:47 PM
