At what boost does an 8 heat range become necessary?
I've been running 7s for a while now, who is running 8s and why? At what point does an 8 become necessary for performance?
Re: At what boost does an 8 heat range become necessary? (turboDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboDC2 »</TD></TR><TR><TD CLASS="quote">I would say run 8's if you run race gas and any decent amount of boost. but just my 2 cents</TD></TR></TABLE>
Re: At what boost does an 8 heat range become necessary? (Jdm_Fast_Orange)
where to get an 8 heat range plug. I wanted to try that out on a dyno heat range 7 vs 8, but my local dealer said me, that he called NGK and they do not make a 8 heat range plug. I run BCP 7es 11 and I wanted an 8es...but it is not available. Damn, I wanted to compare it on the dyno.
If I remember correctly he also told me no 9 10th, I think 11 or 12 is the next step of this brand
Re: At what boost does an 8 heat range become necessary? (VaporTrail)
you can also ttry an r5671a -8 - 9 -10 -11 -12 all different makes in there racing series plug line.
That would be great, you wouldn't happen to know the short # for the 8 heat range BKR would you?
I called NGK tech support about this issue (very knowledgable guys) and there is no BKR in the 8 heat range. You have go with a race plug like R7113-8 (#3650). These plugs arent cheap though.. over $15 a plug
Anyone have a better solution?
Re: At what boost does an 8 heat range become necessary? (Jared)
I run Apexi #8...
I use 100 octane gas daily and boost at 0.8 bar (max) 0.45 daily. I was using NGK #7 but my car would knock after about 7000 rpms, so my tuner switch them to #8's...very nice!!...No knocking, no backfiring, no carbon deposits
SiBirdie
11-08-2003 05:15 PM
