No V-TEC HELP!!
Old Jul 2, 2003 | 05:09 AM
DBallz's Avatar
Default No V-TEC HELP!!
Well this is my problem. I had to rebuild my engine again and after rebuilding I just finish breaking it in. So now this morning I was pushing it up into V-TEC and nothing. I’m also getting a o2 sensor codes which is making my engine run really rich and lean(according to the sensor). Do you think the faulty o2’s are causing the lack of V-TEC engagement. Oh btw I have a 2000 Si with a stoked 2.0L B16 with a Greddy kit. I would really like to fix this problem soon before I just set the car on fire.
Old Jul 2, 2003 | 05:51 AM
GreddySi99's Avatar
Default Re: No V-TEC HELP!! (DBallz)
I dont think an o2 sensor has anything to do with vtec. I would check other things such as oil pressure, VSS, coolant temp, see if the vtec selinoid is getting power and I think there are a couple of other things that have to happen to fire vtec. somebody who knows for sure will chime in
Old Jul 2, 2003 | 05:53 AM
Flamenco-T's Avatar
Default Re: No V-TEC HELP!! (intercooledJRSC)
Did you check all the codes ? The o2 code, was it a primary or secondary ?
stan
Old Jul 2, 2003 | 06:00 AM
DBallz's Avatar
Default Re: No V-TEC HELP!! (Flamenco-T)
Well the o2 is the primary but I figure I just will change both units. But that is the only code that I’m getting.
Could the ecu be in limp mode cause of the o2's if so does limp mode cancel out VTEC?
Modified by DBallz at 3:13 PM 7/2/2003
mramerica05
Feb 20, 2007 09:34 AM
hybridhatch07
Aug 26, 2006 08:42 AM
HUYNH
Aug 2, 2006 01:00 AM
sctan15
Aug 23, 2003 01:51 PM
turbotime
Jun 18, 2003 03:19 PM
