code 14 is pissing me off
Old Jul 2, 2003 | 06:16 PM
Mr. Softee's Avatar
Default code 14 is pissing me off
im getting it. i dont wanna check w/ a multimeter just yet... im abotu to though.
its IACV. ive tried two of them, both threw codes.
any random ideas?
Old Jul 2, 2003 | 06:17 PM
Mr. Softee's Avatar
Default Re: code 14 is pissing me off (94goldjungsr)
i meant to post this in the integra forum, plz move mods i u!!
Old Jul 2, 2003 | 06:19 PM
turbotypeR@SPEC's Avatar
25 Year Member
i just fixed one today that did not have ignition power.i just ran a new wire to it and it worked fine.
Old Jul 2, 2003 | 06:21 PM
Mr. Softee's Avatar
Default Re: code 14 is pissing me off (turbotypeR)
hm interesting. tehres two wires that go into the clip, you merely cut the power one and soldered in a new power source?
Old Jul 2, 2003 | 06:58 PM
25 Year Member
yup!
Old Jul 2, 2003 | 07:17 PM
maxpsi's Avatar
Ah yes, I know that code. First try taking the IACV, wrap the sensor part, and spray some car clean inside the mechanical parts (be generous w/ the carb cleaner). Sometimes they just get stuck over a period of time. If this doesn't work, then start with the electrical side as Danny suggested. If all else fails (as it did with me), then get ready to dish out some $$$ for a new one. Good luck!
Old Jul 2, 2003 | 07:39 PM
Mr. Softee's Avatar
Default Re: code 14 is pissing me off (maxpsi)
i just got another one and it didnt wrok. im gonna try one of my friend's that i know for sure works. this one worked for about a minute or two without any problem then once the car warmed up it stopped working or something like taht who knows. bottom line it isnt working. im going to use a test light on the power source and then go from there
sam
Old Jul 3, 2003 | 06:35 PM
25 Year Member
"then get ready to dish out some $$$ for a new one."
next time let me know.i have several of them as well as many other stock parts.
Old Jul 3, 2003 | 06:59 PM
Mr. Softee's Avatar
I need an LS one, i dunno if an R one will work but i know a GSR one wont, i had an extra.
Okay today i realized that if i pull down on the wires that go intot he clip it seems to make the IACV work. So i swapped otu the clip and soldered in a new oen and it seems to be working now but it throws the code? when i unplug it it idles really low, when its plguged in it idles normal but its still showing the code.
thoughts?
sam
Old Jul 3, 2003 | 07:12 PM
25 Year Member
most honda ones are the same.i have them from h22,d16,& b18.i htink they are all the same.
Old Jul 3, 2003 | 07:16 PM
Mr. Softee's Avatar
the gsr and ls ones are definitely different.
Old Jul 3, 2003 | 08:06 PM
E-Rok's Avatar
EPIC TUNING
what are the symptoms of a bad IAC? my car hesitates and bucks the first 2-3 minutes after startup
Jimmy419Trinh
Honda CR-V & Element
Mar 18, 2024 10:53 AM
90civicgsr
May 3, 2008 12:40 PM
Rukusmasta2
Mar 4, 2006 09:21 AM
undefinedcrx
Mar 12, 2004 01:11 AM
dingusjt
Nov 7, 2003 07:45 AM
