SOHC Turbo questions....... help please
Guest
Posts: n/a
I have a 1994 cx hatch... with as follows:
d16z6 w/ del sol lsd tranny
bbk 255 fuel pump
vortech fpr
AEM CG
ACT Stage 3 clutch
Fields vtec controller
2.5 cat back
NOS Wet kit
I just purchased the greddy turbo kit for my car, witht he big front mount. I would like to know if there is anything that you can forsee that I would need so that i wouldnt have any problems.... I would like to run 10lbs., but i need to get a boost gauge and boost controller.. How many pounds will i run with out the boost controller? ... Basically I want to make close to 300 hrspwr, and I want to know what i will need, with taking the cheapest way about doing it that way.... Thanks for any input...
bbk 255 fuel pump
vortech fpr
AEM CG
ACT Stage 3 clutch
2.5 cat back
NOS Wet kit
Re: SOHC Turbo questions....... help please (JdmVetteEater)
You're asking alot from a little. The stock GReddy SOHC kit doesn't come with a BOV, but it doesn't come with an intercooler either so maybe whoever you're buying from has one. The kit boosts 5.5psi stock, but with an intercooler should drop to around 3-3.5psi with no boost controller.
How do you plan on fueling it? AFC hack? FMU? Hondata? The kit comes with it's own fuel solution (GReddy blue box and FMU), which I personally don't like but.. to each his own. As for 300whp.. not a chance with the GReddy kit. At 10psi (assuming you took car of the fuel) look for 200whp +/-. 300whp will require alot more turbo and an engine to handle it..
Re: SOHC Turbo questions....... help please (VTC_CiViC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_CiViC »</TD></TR><TR><TD CLASS="quote">You're asking alot from a little. The stock GReddy SOHC kit doesn't come with a BOV, but it doesn't come with an intercooler either so maybe whoever you're buying from has one. The kit boosts 5.5psi stock, but with an intercooler should drop to around 3-3.5psi with no boost controller.
How do you plan on fueling it? AFC hack? FMU? Hondata? The kit comes with it's own fuel solution (GReddy blue box and FMU), which I personally don't like but.. to each his own. As for 300whp.. not a chance with the GReddy kit. At 10psi (assuming you took car of the fuel) look for 200whp +/-. 300whp will require alot more turbo and an engine to handle it..</TD></TR></TABLE>
Couldn't agree more. No way to get 300 horse out of just the greddy kit.
Guest
Posts: n/a
Re: SOHC Turbo questions....... help please (romeo619romeo)
I am getting the big frnt mount.... so you are sayign that with the big front mount it will only run about 3.5 pnds.... That wouldnt be to fast... Right now i runa 13.2 spraying a 75 shot....
stock boost on the greddy kit is 5.5. with a large front mount, u will get a pressure drop. i've seen some only drop to about 4 psi.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmVetteEater »</TD></TR><TR><TD CLASS="quote">Also I was planning on doing the vafc hack... but in the future going hondata.... so a bosst controller is a must then i take it?</TD></TR></TABLE>
AFC hack will be fine up to 10psi, but i'd look into a real fueling system i.e. Hondata asap.
And yes a boost controller is neccesary... if you want to boost more than what the wastegate is set at anyways.
Xander teh Grate!
06-01-2004 08:05 PM
redline201
05-01-2002 02:51 AM
