What do I have to do to make my LS a 2.0?
I'm currently running a B18 w/ direct port nitrous. It's already built with JE pistons, Eagle rods, Crower valvetrain...etc etc. I want to rebuild it 2.0 and sleeve it.
1st question is...is it worth it?
2nd..what exactly do I have to replace to make it a 2.0?
(rods,bigger pistons,crank?)
Re: What do I have to do to make my LS a 2.0? (whatVTEC)
Read this thread. Some very useful info here.
https://honda-tech.com/zerothread?id=543984
HELLO,GOOD MORNIN'
Re: What do I have to do to make my LS a 2.0? (2.2Lcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2Lcivic »</TD></TR><TR><TD CLASS="quote">84.5mm bore should do it.</TD></TR></TABLE>
sounds good to me, but why again. Just get a crv block and build it.....then you have your 2.0 then maybe a little more.
Re: What do I have to do to make my LS a 2.0? (HybridcivicLS-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T »</TD></TR><TR><TD CLASS="quote">
sounds good to me, but why again. Just get a crv block and build it.....then you have your 2.0 then maybe a little more.</TD></TR></TABLE>
Huh? That would be a waste of $$$... I wanted to go 2.0L, read up on it, and am going to go with an 81mm bore most likely. It will be a daily driven street car with lots of abuse so I would like to make it as reliable as possible.
Re: What do I have to do to make my LS a 2.0? (mskibbz-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">I wanted to go 2.0L, read up on it, and am going to go with an 81mm bore most likely. It will be a daily driven street car with lots of abuse so I would like to make it as reliable as possible.</TD></TR></TABLE>
The only way to go 2.0 with an 81mm bore is to 'stroke it baby.'
Buy a prelude b21a or b20a crank. That should get you close to 2.0. There are more expensive aftermarket crank options also. You should really deckplate your motor to retain a decent rod/stroke ratio if you're going to be doing this tho. You probably wont want to rev it as high as with a smaller stroke.
Not that any of this is cost effective or even a good idea, but that is 'how.'
Edit: This is how to do it correctly:
https://honda-tech.com/zerothread?id=543823
Re: What do I have to do to make my LS a 2.0? (94goldjungsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr »</TD></TR><TR><TD CLASS="quote">why do you want a 2 l....</TD></TR></TABLE>
I'm not sure if I do or not...that's why I'm trying to get some insight from everyone here. After reading that thread, I'm not sure I want to do it anymore
Sinner
07-29-2004 11:34 AM
94civicexlsvtec
15
01-03-2004 12:19 PM
