detonating after turbo UNinstall
Old Jul 4, 2003 | 01:45 PM
MachAF's Avatar
Default detonating after turbo UNinstall
PROBLEM FIXED: I'm a ******* idiot. One of my header bolts wasn't tight. Tighten it up and knocking sound went away. on me!! KISS!!!!!!!!!!!! All that panicing for nothing I feel so stupid now
I removed my turbo a week ago, but I just got the car finished up today.
I did solder my stock injectors back in and cut the wires off the greddy blue box and resolder the map sensor wire.
I started it, let it warm up. took it around the block, everything was fine.
So I park it. Go back out a few hours later. Start it, I get a weird knock noise when it starts, and when I rev it, it knocks too. Sounds like its detonating to me.
I checked the plugs, they look normal. One spark plug wire got a lilttle bit smashed by a nut, doesn't look bad at all.
No CEL's either. Motor is a b18c1. Shouldn't my knock sensor detect it detonation?
Anyone have an ideas?
Modified by MachAF at 5:33 PM 7/4/2003
Modified by MachAF at 1:42 PM 7/5/2003
Modified by MachAF at 1:44 PM 7/5/2003
Modified by MachAF at 2:22 PM 7/5/2003
Old Jul 4, 2003 | 02:51 PM
iam7head's Avatar
Default Re: detonating after turbo UNinstall (MachAF)
I forgot to change my FPR when i uninstall my turbo, lucky i found out before it blow up..
Old Jul 4, 2003 | 03:51 PM
MachAF's Avatar
Default Re: detonating after turbo UNinstall (iam7head)
Changed spark plugs and checked my FPR. Still making the same noise.
damn this is pissing me off. No codes even.. wtf
Old Jul 4, 2003 | 03:54 PM
tony1's Avatar
Hate to be the bearer of bad news, but you won't hear detonation like that. Sounds like you have a rod knock. You DID remember to put oil back in the motor after removing the turbo, right? Check your oil and possibly pull the oil pan and check the bearings...
Old Jul 4, 2003 | 04:11 PM
MachAF's Avatar
Default Re: detonating after turbo UNinstall (tony1)
Yes I remember to fill it up with oil. Oil level is fine.
So you think I smoked my bearing. How could have this happened?
I was boosted for 20 miles.
After I put oil in the car, I let it fully warm up. And took it around the block came up and parked it. Everything sounded fine during that quick trip. Few hours later go back out and its making that noise.
Any other ideas?
Thanks for the response Tony.
Old Jul 4, 2003 | 04:29 PM
tony1's Avatar
It's real hard to say w/o hearing it, but from what you described, it's a spun rod bearing. Drain the oil into a clean pan and look at it in the sunlight. If the oil is metallic looking then drop the pan and check the bearings...
Old Jul 4, 2003 | 04:54 PM
MachAF's Avatar
I checked the oil.
My dad and I both agreed it wasn't metallic. There were some air bubbles though.
The motor idles fine too, no knocking. It knocks right at start up when stops. If I use part throttle and rev the motor It won't knock. But If I use a lot of throttle it will knock.
So my next step is to take out the oil pan and check the connecting rod bearing? And what exactly am I looking for? Thanks
Old Jul 4, 2003 | 06:03 PM
Mr. Softee's Avatar
i honsetly think you are hearing things.
Old Jul 4, 2003 | 06:41 PM
MachAF's Avatar
Default Re: detonating after turbo UNinstall (94goldjungsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">i honsetly think you are hearing things.</TD></TR></TABLE>
No man its making wierd noise. trust me. I'm just never going to mod my car agian. I always get fucked.
Old Jul 5, 2003 | 10:04 AM
MachAF's Avatar
up
1slowcrx
Jan 8, 2012 11:15 AM
DACteg
Apr 30, 2007 09:32 AM
Whiteintegra
Jul 29, 2006 01:13 PM
MachAF
Jul 5, 2003 10:08 AM
Ray
Jul 2, 2001 04:01 AM
