Custom intercooler piping and Down pipe.
Old Jul 1, 2003 | 06:34 PM
SSS2000's Avatar
Default Custom intercooler piping and Downpipe question.
My setup is going to be a precision SC34 .63a/r on a LS running about 11psi. I was going to do custom piping from JC Whitney and didn't know what size to run (2 1/4 or 2 1/2) from the turbo to intercooler and intercooler to throttle body. The inside diameter of the pipe is about 1/8 inch smaller, does this matter?
Would I be able to make a 3 inch downpipe fit and keep a/c , using an inlinepro manifold. Would the 3 inch be needed if i was going to make a transition from 2 1/2 to 3 under the oil pan?
Sorry for the long post. and i did a search for those flamers out there.
Thanks!
Modified by MilanoRedLST at 10:52 PM 7/1/2003
Old Jul 2, 2003 | 05:54 AM
SSS2000's Avatar
Default Re: Custom intercooler piping and Downpipe question. (MilanoRedLST)
28 views and no posts?
Old Jul 2, 2003 | 06:01 AM
SSS2000's Avatar
I did some more searches and found what size intercooler piping to use, but i'm still curious to know if I will be able to make a 3" downpipe and keep a/c with an Inlinepro mani.
Old Jul 2, 2003 | 06:23 AM
Overblown-Teg's Avatar
you would probably be better off with a 2.5" downpipe and transition it up. to make the 3" fit you will need to cheat the bends pretty bad which is worse for flow than having the 2.5" pipe.
Old Jul 2, 2003 | 07:32 AM
Burke's Avatar
Banned
Default Re: (Overblown-Teg)
dude, we could always **** around and try to fab up a 3in downpipe. my welds just arent that pretty, yet........
Old Jul 2, 2003 | 07:35 AM
quikB18B's Avatar
Default Re: (Burke)
On piping im going with 2.25 into intercooler and 2.5 out, 2.25 all the also ok too.
On the manifold im having tony1 make me a downpipe 2.5- 3" and still retain a/c with the inline pro manifold.
bump for the exact setup im gonna run
Old Jul 3, 2003 | 04:35 AM
SSS2000's Avatar
Default Re: (Burke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burke &raquo;</TD></TR><TR><TD CLASS="quote">dude, we could always **** around and try to fab up a 3in downpipe. my welds just arent that pretty, yet........
You better start practicing then.....did you get that five bolt flange yet so you can finish your car? I'm starting on mine in 2 weeks!!!
Old Jul 3, 2003 | 04:38 AM
Burke's Avatar
Banned
Default Re: (MilanoRedLST)
YES my flange will be donw today by noon or so. as soon as i get off work i am gonna weld it and then throw the bitch on and HOPE she starts. i have only been waiting 2 MONTHS for this!!!!!
so the plan is to be driving by 3 o'clock this afternoon i'll let you know it all works....
later
Old Jul 3, 2003 | 05:01 AM
oscarmayer's Avatar
if you have the ability to go 3" fine, if not, then go 2.5" try to stay as big as you can. also you will need to change the cat and the rest of your exhaust system to match the size of the down pipe. what's the point in having a 3" down pipe of you have a stock cat and a 2.25" cat back? it's a total bottle neck and will ruin any flow gained by the larger down pipe.
Old Jul 3, 2003 | 05:12 AM
Burke's Avatar
Banned
Default Re: Custom intercooler piping and Downpipe question. (oscarmayer)
hes got an exhaust already, i think 2.5. i think he should go 3 in all the way.
i do have a 10 foot section of 3in pipe and a welder....... perhaps we can rig something up
1990hondaHF
Aug 16, 2006 10:17 PM
nate951
Feb 6, 2005 07:19 PM
ghettochild
Aug 10, 2004 07:02 PM
JM Performance
Jan 1, 2004 08:02 AM
R6Boy69
Jun 21, 2001 09:42 AM
