TurboXS Dual stage boost controller main connector help ( missing plug)
Old Jul 25, 2004 | 08:53 PM
b18cx's Avatar
Default TurboXS Dual stage boost controller main connector help ( missing plug)
No idea what happened to the connector/plug. If someone could help out here.
After testing with my multimeter, pin 1 and 3 are common. Assume that would be the 12v input. Pin 2 is common with the brass mount. Assume thats the ground.
the instruction sheet says there is only 2 wires. one ground and one power, yet there are three pins. Just want to be sure. TIA.
Old Jul 26, 2004 | 07:11 AM
b18cx's Avatar
Default Re: TurboXS Dual stage boost controller main connector help (b18cx)
any help out there??
Old Jul 26, 2004 | 07:24 AM
tommyten's Avatar
you should IM "littlebluecrx" & "xxxracing" here on honda-tech...they have been running that boost controller for some time so they should be able to help you.
for how much did you get that boost controller by the way?
Old Jul 26, 2004 | 11:04 PM
turtle-eg's Avatar
Yes, there are only two wires... I have one on my car... I have to double check this tomorrow, but all you have to do is have power to pin 2 and ground to either 1 or 3 because on the plug they supply, it can be installed either up or down.
B20EF
Feb 22, 2008 04:44 PM
rudebwoy
Feb 7, 2006 11:09 AM
StreetProjectz
May 2, 2005 02:45 PM
blackdelsolsi
Oct 18, 2003 10:12 PM
