OneFAB h22 prelude Setup
Old Jul 27, 2004 | 11:21 PM
This One's Avatar
Default OneFAB h22 prelude Setup
We just finished our Series ONE H22 Setup for preludes/accords.
The manifold is Closer Equal Lenght than most Avail. Within .5" between runners If that. Standard materials, 8g 304.....
Little to NO Cutting to Fit full 3" Dp.
Slight notching of the Crossmember recomended unless Solid motor mounts are used. The DP Fits without notching, We recomend it to make it live from being crushed from the movement of the motor on stock mounts.
All of you will be quick to notice the low placement of the turbo, There isnt much you can do with this because of the Alternator, The Turbo must sit below it.
There is still adequate room and placement to properly run a Return line.
Let us know what you think and check out our new Site should be up within the next few days...
Modified by This One at 2:20 PM 8/13/2004
Modified by This One at 6:26 PM 8/13/2004
Old Jul 28, 2004 | 12:46 AM
Charles B.'s Avatar
Default Re: OneFAB h22 prelude Setup (This One)
looks good
Old Jul 28, 2004 | 02:29 AM
turboekcivic's Avatar
i likes can i have it?
Old Jul 28, 2004 | 07:58 AM
This One's Avatar
Default Re: OneFAB h22 prelude Setup (turboekcivic)
Thanks
Old Jul 28, 2004 | 09:08 AM
DCbb6's Avatar
this is for all 97+ preludes with the modifications you've mentioned correct????
Old Jul 28, 2004 | 09:39 AM
ludetech
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboekcivic &raquo;</TD></TR><TR><TD CLASS="quote">i likes can i have it? </TD></TR></TABLE>
no its mine Thanks Matt Im looking forward to jumping from no mods at all to full build and turbo lol
Old Aug 13, 2004 | 10:07 AM
This One's Avatar
Default Re: OneFAB h22 prelude Setup (DCbb6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCbb6 &raquo;</TD></TR><TR><TD CLASS="quote">this is for all 97+ preludes with the modifications you've mentioned correct????</TD></TR></TABLE>
Yes Same Kit,
We Dont know about previous models at this point.
But Assuming it is generally the same w/ little modification.
We should have an f series version avial as well
Old Aug 13, 2004 | 11:08 AM
prelittlelude's Avatar
that dump tube and waste gate sit right where the radiator should, am i missing something or is that the ac condensor or is that the radiator moved forward?
nice work none the less ,
Old Aug 13, 2004 | 11:19 AM
This One's Avatar
Default Re: OneFAB h22 prelude Setup (prelittlelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude &raquo;</TD></TR><TR><TD CLASS="quote">that dump tube and waste gate sit right where the radiator should, am i missing something or is that the ac condensor or is that the radiator moved forward?
nice work none the less , </TD></TR></TABLE>
Civic Half radiator is a Must, the Ac condensor is still on that car just because its wasnt removedas of that picture.
It is a non a/c setup
Old Aug 13, 2004 | 11:24 AM
RIPracing's Avatar
wow thats looks nice let me know what kind of power u make!!!
Old Aug 13, 2004 | 11:28 AM
G
sh!t happens.
Default Re: OneFAB h22 prelude Setup (RIPracing)
that is a nice looking manifold the the h-series.. like to see a dyno chart with the manifold.
Old Aug 13, 2004 | 11:42 AM
BoostedH23Accord's Avatar
thats one of the sexiest manifolds Ive seen yet. Hmmmmmmm
Old Aug 13, 2004 | 11:44 AM
JDMH22HATCH's Avatar
Looks great. I was amazed at the quality of the manifold when I had the chance to see it in person in Dallas this past weekend
Old Aug 13, 2004 | 03:14 PM
Maintenance's Avatar
Default Re: OneFAB h22 prelude Setup (JDMH22HATCH)
manifold is very nice
Synapse Motorsport
Apr 27, 2008 04:58 PM
Mykizism
Welding / Fabrication
11
Mar 13, 2008 09:52 AM
cpmike
Dec 6, 2005 01:31 PM
This One
Aug 21, 2004 02:37 PM
Griffins_Importuning
12
Oct 23, 2002 03:24 PM
