Send it back??? or is it an easy fix??
Old Jul 28, 2004 | 07:23 PM
SpoolnG2's Avatar
Default Send it back??? or is it an easy fix??
Just put a new tranny in my gfs car and got everything done....hooked up ready to go. Filled it with fluid and was about to take it off the jacks when i noticed a tiny bit of fluid by one of the bolts. Anyways......turns out there is like a super tiny hairline crack...very minute.....about 1/2 inch long. I wipe it...and about 30 sec. later a little bit of fluid comes back to that spot. I just drained the trans tonight....my question is do i send it back for another one? or can i just put some JB Weld over the hairline crack? what are your reccomendations? use something else...use JB Weld...send it back?
Thanks,
Josh
Old Jul 28, 2004 | 07:26 PM
Charles B.'s Avatar
Default Re: Send it back??? or is it an easy fix?? (SpoolnG2)
jb weld may work. if you send it back to whomever will they replace the tranny with a new one?
Old Jul 28, 2004 | 07:29 PM
DigitalFusion's Avatar
Default Re: Send it back??? or is it an easy fix?? (CharlesInTurbocharge)
have someone w/ a tig welder run a qwik bead
Old Jul 28, 2004 | 07:32 PM
Charles B.'s Avatar
Default Re: Send it back??? or is it an easy fix?? (DigitalFusion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DigitalFusion &raquo;</TD></TR><TR><TD CLASS="quote">have someone w/ a tig welder run a qwik bead</TD></TR></TABLE>
even better
Old Jul 28, 2004 | 08:54 PM
SpoolnG2's Avatar
so just have like a trans shop throw a weld in place of it....should be fine then?
Old Jul 28, 2004 | 09:00 PM
Charles B.'s Avatar
doesn't have to be a trans shop. if it's just a hairline crack, welding it should be fine.
Old Jul 28, 2004 | 09:30 PM
honda9369's Avatar
Old Jul 28, 2004 | 10:10 PM
Suprdave's Avatar
Prolly got owned in shipping....RTV
Old Jul 28, 2004 | 10:55 PM
TurboTony's Avatar
If they will give you a new one I would send it in, if shipping is not that expensive. If not just JB weld or have someone with a tig welder fix it real quick.
Old Jul 29, 2004 | 05:11 AM
SpoolnG2's Avatar
Default Re: Send it back??? or is it an easy fix?? (TurboTony)
gonna call today on pricing to see if a shop can braze it. If not just throw a weld on there.
Old Jul 29, 2004 | 05:28 AM
SpoolnG2's Avatar
just talked to the trans shop....they said if u wanted to, u could take it somewhere that welds trans' but JB Weld would do fine for the fix. They just said to make sure u prep the surface well. So i'm gonna try JB Weld and if it doesnt work...oh well....then i'll take it to be welded.
Old Jul 29, 2004 | 06:15 AM
Honda Hick's Avatar
Thats good to let the seller know about any problems and what you did to fix it just to cover your *** if something goes wrong.
BokudenNYC
Oct 16, 2008 04:38 PM
Tech-Nics
May 12, 2008 03:30 AM
blackrag
10
Feb 10, 2007 10:40 AM
B16b-EJ8
Sep 11, 2006 02:17 PM
RicharDC4
Feb 20, 2005 09:46 AM
