best turbo to use with this set up?????
i need to know what is the best turbo to use with my setup.
b18c1 GSR
Fully built bottom end with-
Arias dished 9:1 comp
Eagle rods
type r balanced crank
81.5 mm
golden eagle block guard
arp head studs
new oil pump
water pump
HEAD
i got my head hot tanked and magnaflux then
new springs
retainers
stock cams for right now but in like 2 weeks new stage 2
new turbo head gasket
TRANSMISSION
Findanza 8lb flywheel
stage III 6 puck sprung clutch
lsd
shortshifter
TURBO
i already have the turbo xs rfl bov with the intercooler piping and a huge front mount.
now my real questions are is what turbo should i use and wat size injectors should i use. and if you think any thing else would go nice let me know thanks
b18c1 GSR
Eagle rods
81.5 mm
arp head studs
new oil pump
water pump
HEAD
new springs
retainers
TRANSMISSION
lsd
shortshifter
TURBO
Re: best turbo to use with this set up????? (raceteamintegra86)
you should have gone with a NON-aluminum flywheel, because heating up aluminum is not the greatest thing, especially for a monster setup that youre aiming for
Re: best turbo to use with this set up????? (boostedcivichatchbacksi)
It really depends on what your goals are, do you plan to race mostly on the street or track. How often do you drive your car. How much power were you looking to make.
i plan on racing the streets most of the time. i will prob be at the track no more then 4 times a month and i want to rearch at least 350 hp if nto more. do you think a t70 is to big even wtih a biult motor
That turbo is a lil big. You would be good to go with a precision sc44 turbo, or maybe a gt30 turbo.
so dotn go with a t3 t4 niether. i really like the t70. how big is it really compared to a drag t3 t4?????
i ♥ my honda
Global Mod
Global Mod
Re: best turbo to use with this set up????? (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 »</TD></TR><TR><TD CLASS="quote">your sig says you already have it
and yes, get a t70 for 350whp </TD></TR></TABLE>
LOL t70 that is funny
Traceteamintegra86>> that's WAY to Big!
You wont hit full boost till 6500. That is such an overkill with that setup its no even funny. Maybe if you spooled it up with a 150 shoot of N20
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raceteamintegra86 »</TD></TR><TR><TD CLASS="quote">so dotn go with a t3 t4 niether. i really like the t70. how big is it really compared to a drag t3 t4?????</TD></TR></TABLE>
lol, you really like the T70. Ever driven it? Terrible turbo for surging, way too big for your setup, or any other street honda. Most i've seen out of a T70 is 730 RWHP on a domestic, so it's just a pinch bigger than a T3/TO4E 57 trim
