Question about my InlinePro Manifold!
Old Jul 27, 2004 | 10:25 PM
B00ST2nR's Avatar
Default Question about my InlinePro Manifold!
Ok so I picked up my InlinePro Manifold today. I also picked up my Tial Waste Gate and Tial BOV.
Now the manifold I got has a different looking WG Flange.
The one's I saw looked like this:
(T3 5 bolt)
The one I got looks like this:
(T3 4 bolt)
Notice how the WG Flanges look different. The top one looks like the flange on the Tial WG. The one I got (bottom), the flange looks like a ninja star.
Now my questions is... will the standard Tial WG work with the Manifold I got? Or did I pick up the wrong Manifold??
Old Jul 27, 2004 | 10:29 PM
tub_sephiroth's Avatar
Default Re: Question about my InlinePro Manifold! (B00ST2nR)
Yes it will work. Notice the other flange doesn't have holes. That was made for a 4 bolt turbo. The manifold on top is for a 5 bolt turbo. Which turbo do you have?
Old Jul 28, 2004 | 12:50 AM
Charles B.'s Avatar
Default Re: Question about my InlinePro Manifold! (tub_sephiroth)
i think both will fit a 35/38mm gate. i think the one for the 4-bolt (bottom picture) has the star design in case you wanna drill and tap for a 40mm gate??? someone correct me if im wrong...
Old Jul 28, 2004 | 12:58 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Question about my InlinePro Manifold! (CharlesInTurbocharge)
well does your turbine discharge have a 4 or 5 bolt downpipe. If you have the 4 bolt then you got the right manifold. The 38m will fit.
art
Old Jul 28, 2004 | 08:47 AM
B00ST2nR's Avatar
Default Re: Question about my InlinePro Manifold! (Arturbo)
I purchased an SC61 turbo, and I believe the turbine discharge has the 5 bolt DP. (It's on its way right now)
Now the thing I don't get is... why won't my manifold work with a 5 bolt turbo? It's only the Downpipe Discharge flange that needs the 5 bolt right? The flange from the Turbo manifold to the Turbo matches up. So I don't get why there's a distinguishment between 4 bolt and 5 bolt Manifolds. I understand 4 bolt and 5 bolt Turbo's need 4 bolt or 5 bolt Discharge flanges from the Down Pipe...
Someone please clearify for me. Thanks.
Old Jul 28, 2004 | 08:59 AM
Rory Breaker's Avatar
The 4 bolt manifold with a 5 bolt turbo places the turbine in the block. I believe you will have to grind the **** out of it to fit it if its possible at all. I know a few people have done this in past threads, Im not sure the extent of the work involved.
Like we said before, you really should use a 4bolt turbine housing with this manifold. I saw some badass 4 bolt Garrett/Precisions in the Classifieds around the time I sold the manifold that totally tempted me to just get another turbo.
Old Jul 28, 2004 | 09:34 AM
B00ST2nR's Avatar
Default Re: Question about my InlinePro Manifold! (newgsrdriver)
aw damn. I already purchased my Turbo and it's on the way.
I guess I bought the wrong manifold like you did newgsrdriver. ****...
Old Jul 28, 2004 | 04:31 PM
eddyboy's Avatar
Would you like to know more?
https://honda-tech.com/zerothread?id=402894
Hope it helps.
Old Jul 28, 2004 | 09:19 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Question about my InlinePro Manifold! (eddyboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eddyboy &raquo;</TD></TR><TR><TD CLASS="quote">Would you like to know more?
Hope it helps.</TD></TR></TABLE>
Now keep in mind I wrote that when the 4 bolt wasnt available. If you are running a 4 bolt turbine housing you must run the manifold made for that which is a cast iron piece. If you are running 5 bolt then you must run the cast iron or cast stainless steel manifold made to work with the 5-bolt.
art
Old Jul 28, 2004 | 09:41 PM
TurblowR's Avatar
dont worry its not that much grinding. if you want to see how much i grinded off ill be up north in 2 weeks.
96electronH
Mar 21, 2011 04:44 AM
KdF
Sep 23, 2010 07:14 PM
Patron
Feb 13, 2004 08:35 AM
evoeone
Mar 6, 2003 05:40 PM
Eric J
Jan 1, 2002 08:46 AM
