is there any way to check if injectors are flowing properly?
and if one or two injectors were not flowing properly what would the spark plugs look like?
Re: is there any way to check if injectors are flowing properly? (PBOOSTIN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PBOOSTIN »</TD></TR><TR><TD CLASS="quote">and if one or two injectors were not flowing properly what would the spark plugs look like?</TD></TR></TABLE>
I'd think the plugs would look leaner at those two cyl's than others, if you were to line them all up and look at them.
Re: is there any way to check if injectors are flowing properly? (Sinitron)
you can hook them up to a fuel supply and spray them into a graduated cylinder for a set amount of time. At least you will know the volume they move is equal and I guess you could just eyeball the spray pattern...just an idea
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sinitron »</TD></TR><TR><TD CLASS="quote">
it's always some thing!
12
05-12-2008 07:30 AM
russianswty
01-10-2007 08:32 AM
chad
10-27-2004 06:21 PM
