Leak down and Compression test results
Old Jul 28, 2004 | 01:43 PM
TurboJesse
Guest
Posts: n/a
Default Leak down and Compression test results
Well i bough a 92 DX hatch last week of a friend (WAY too good of a deal to pass up ) The car had some problems...Ghetto SMC management (running WAY rich), Hacked wiring, dented oil pan/shitty oil return) that needed fixing and my friend just wanted rid of the car...Anyways i fixed all the wiring issues, ditched the SMC and tuned the car on uberdata.
Setup is:
b18c1
9:1 JE's
Eagle rods
JG Pro series head (complete valvetrain/valves/PnP)
Drag 3 turbo kit
Uberdata
DSM 450's (temporary )
Walbro 255hp
Results of the comp/leak test were:
165, 165, 170, 162
2%, 2%, 3%, 0%
The car runs perfect part throttle and idles perfect. In boost it still smokes though and i can smell the oil. Im wondering if it could be the ghetto *** return/pan setup (new one goes on this weekend) or possible teh turbo (ive hear story's about the older turbonetics used in the drag 3 kits having problems with the seals )...
Old Jul 28, 2004 | 01:46 PM
boosted_dc2's Avatar
Default Re: Leak down and Compression test results (Mpir3)
how much did you get it for??? compression seems kinda low, but still consistant.
Landon
Old Jul 28, 2004 | 01:47 PM
drvfast's Avatar
Yea I think it's the oil return line. I am having that same problem and I know its the oil return line.
Old Jul 28, 2004 | 01:49 PM
TurboJesse
Guest
Posts: n/a
Default Re: Leak down and Compression test results (boosted_dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">how much did you get it for??? compression seems kinda low, but still consistant.
Landon</TD></TR></TABLE>
my 9:1 b16 pulled the same numbers and made 260whp @ .45 bar
Paid less than $4500 for the car, it also came with rota slips, Golden eagle intake manifold, GSR leathers, etc..Car is white and no rust/clean body (hard to find for less than $3500 STOCK in the northeast ) Im swapping the turbo/injectors and bunch of misc. things off my sol onto it...Should be an easy 400+whp setup
Old Jul 28, 2004 | 04:06 PM
TurboJesse
Guest
Posts: n/a
Just pulled teh turbo from the drag kit off to swap on my Garret BB and it appears the turbo is def the problem. oil CAKED all in the exhaust housing and along the oil return
Old Jul 28, 2004 | 04:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 &raquo;</TD></TR><TR><TD CLASS="quote">
my 9:1 b18c1 pulled 205 accross the board 3 days ago
Landon
Old Jul 28, 2004 | 04:32 PM
hoggy's Avatar
These numbers can be quite different from one compresion tester to another and at different altitudes I would assume as well. It is just important for the numbers to be consistent. His motors sounds like its fine considering his leakdown numbers look good and his numbers are consistent.
MonkeyManStunna's Avatar
damn i get my compression test and leak down test done on Sat i hope i put out as good as numbers as you man
-Landon
Old Jul 28, 2004 | 04:48 PM
TurboJesse
Guest
Posts: n/a
Default Re: Leak down and Compression test results (hoggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoggy &raquo;</TD></TR><TR><TD CLASS="quote">
These numbers can be quite different from one compresion tester to another and at different altitudes I would assume as well. It is just important for the numbers to be consistent. His motors sounds like its fine considering his leakdown numbers look good and his numbers are consistent.</TD></TR></TABLE>
exactly..i was more interested in the leakdown as a ASSumed it might have been teh rings..
Old Jul 28, 2004 | 05:30 PM
dunkd's Avatar
wow what a deal... looking to sell the slips? possibly trade for 96 gsr's? https://honda-tech.com/zerothread?id=938085
Old Jul 28, 2004 | 05:32 PM
99B16Si's Avatar
damn 0%??? ive never seen that, u sure u did the test correctly???
for 0% there would have to be no ring gap...wierd IMO
Old Jul 28, 2004 | 05:34 PM
TurboJesse
Guest
Posts: n/a
Default Re: (99B16Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99B16Si &raquo;</TD></TR><TR><TD CLASS="quote">damn 0%??? ive never seen that, u sure u did the test correctly???
for 0% there would have to be no ring gap...wierd IMO</TD></TR></TABLE>
i thought it was weird too...the gauge might have been off a little.
Old Jul 28, 2004 | 05:52 PM
B18C1CYA's Avatar
Default Re: (Mpir3)
your numbers look fine for 9.1 compression, and i think your in the right derection with the turbo being the culprit
DroppedDisaster
May 26, 2012 12:24 AM
myjohnson
Jul 27, 2011 10:42 AM
projectEGhatch
Apr 29, 2011 04:53 AM
MADBADGER
Honda S2000
54
Jul 18, 2008 11:26 AM
FOrSfEd
Jun 1, 2004 09:02 AM
