check engine light and only 5 psi?
Old Jul 26, 2004 | 05:41 PM
andwutgsr's Avatar
Default check engine light and only 5 psi?
im having trouble with my car only seeing 5 psi. hondata s200b with obd1 p72. no leaks anywhere. starting see the check engine light come on when cruising on highway at 60 or 3k. it does hiccup sometimes when i let off or slow down. check engine light comes on out of nowhere and stays lit until i turn off the car. after i start it up again it goes away. boost controller maybe? but it holds 5psi steady and no drop off.
any help appreciated. running 5psi weaksauce and horrible gas mileage sucks
Old Jul 26, 2004 | 06:33 PM
mrbsponge's Avatar
if when idling it sounds like you have a set of mean *** cams, its probably your map sensor, either over gassed, in the rom range somewhere, or too much boost on the stock sensor, mine did this before the uberdata.......
Old Jul 26, 2004 | 07:17 PM
andwutgsr's Avatar
Default Re: (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">if when idling it sounds like you have a set of mean *** cams, its probably your map sensor, either over gassed, in the rom range somewhere, or too much boost on the stock sensor, mine did this before the uberdata.......</TD></TR></TABLE>
what would be the solution to solving this problem? im willing to try anything at this point.
Old Jul 26, 2004 | 10:28 PM
andwutgsr's Avatar
Default Re: (andwutgsr)
help
Old Jul 27, 2004 | 04:48 AM
dennis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andwutgsr &raquo;</TD></TR><TR><TD CLASS="quote">help</TD></TR></TABLE>
Pull the code...
Old Jul 27, 2004 | 05:08 AM
toolowsol's Avatar
Default Re: (dennis)
Yeah, WHAT code are you throwing, there are about 40 of them Pull the code, then try to figure out why your getting it. It probably isn't even a map code.
GSRTURBO696911
Oct 21, 2005 09:55 PM
tub_sephiroth
Apr 16, 2005 06:22 PM
XX Boosted Si XX
Aug 21, 2004 01:30 PM
90teg
Aug 28, 2003 01:45 PM
StinkyTofu
14
Aug 24, 2003 05:49 PM
